    Jellyfin Forum Support Troubleshooting Going Crazy
    Going Crazy
    Sql Database corrupting
    n4tur3502
    2024-06-29, 01:45 AM
    I am going out of my mind trying to figure out why this keeps happening. After a seemingly random amount of time my sql database corrupts.
    It is always the same message in the log
    Corrupt: SQLitePCL.pretty.SQLiteException: database disk image is malformed
    and I end up having to delete the database file and rescan.
    It has gotten worse over the past 6 months, I now have to delete the database file every couple of weeks.
    I am running jellyfin on an ubuntu server 20.04.6 and a few other things running on it, but none of those seem to have any issues with anything.
    Can anyone please help me figure out what is going on so I can stop pulling my hair out?
    2024-06-29, 01:54 AM
    Are you running out of disk space? How large is your root volume? Transcodes are written to disk and if the root volume is small you may be filling up the disk with transcodes or remuxes.
    n4tur3502
    2024-06-29, 02:04 AM
    I thought of the disc space but I am only using 10% of the available space as far as I can tell.
    /dev/sda2            ext4      238169856    20534980  205463716  10% /
    2024-06-29, 02:10 AM
    Do you happen to have the full jellyfin logs from when this problem last happened?
    n4tur3502
    2024-06-29, 02:22 AM (This post was last modified: 2024-06-29, 02:23 AM by n4tur3502. Edited 1 time in total.)
    I am having issues getting the log to upload. and it says its too big for pastebin. I tried dragging the file to the upload section but it just says release to initiate upload and does nothing.
    Zip the log file first. There is a 2.9MB size limit.
    n4tur3502
    2024-06-29, 02:24 AM
    I am not a smart man.
    .zip   jellyfin20240628.zip (Size: 88.91 KB / Downloads: 140)
    2024-06-29, 02:29 AM
    Is there a log file from before it started? This one starts off with the DB already in a bad state.
    n4tur3502
    2024-06-29, 02:32 AM
    This is the furthest back I have a log for.
    .zip   jellyfin20240625.zip (Size: 29.13 KB / Downloads: 131)
    2024-06-29, 02:37 AM
    Looks like it was already starting to have issues in that log as well. I need to see your log as soon as you start having issues so I can see what it was doing right before the problem starts.
    Probably unrelated, but you enabled NFO saver and Jellyfin doesn't have write permissions to your media folders.
    [2024-06-25 04:40:51.231 -04:00] [ERR] Error in metadata saver
    System.UnauthorizedAccessException: Access to the path '/media/Media/Video/Movies/Regular/Furiosa (2024)/Furiosa A Mad Max Saga (2024) WEBRip-1080p.nfo' is denied.
    ---> System.IO.IOException: Permission denied
