    Jellyfin Forum Support Troubleshooting Going Crazy
    Going Crazy
    Sql Database corrupting
    n4tur3502
    2024-06-29, 02:40 AM
    Sonofa, i thought I fixed that. Ill just turn that off for now. The problem is i dont always notice when the issue happens. It is usually like a couple days later when I notice it isnt updating libraries. Do you think this could be related to my sonarr/radarr setup? or possibly i also have ersatztv setup to access jellyfin as well.
    2024-06-29, 02:42 AM
    Keep in mind this log is from 3 days ago so you may have fixed that. I was just making you aware if you hadn't.
    I don't see how any of those apps could affect Jellyfin in this way.
    n4tur3502
    2024-06-29, 02:43 AM
    Ok, cool. I am going to delete and rescan tomorrow. I will keep an eye on it and if I see it again I will grab all the logs I can. Is it ok if i leave this post open until then? I really appreciate the help.
    2024-06-29, 02:50 AM
    Yep. Just update the thread whenever you start see anything odd and include your logs.
    Also, can I have the full specs of your system? Is the root volume on a SSD or HDD?
