    Jellyfin Forum Support Troubleshooting Issue with trickplay
    Pages (4): 1 2 3 4 Next »
    Trickplay stops at 62%
    playserver
    2024-05-13, 11:04 PM (This post was last modified: 2024-05-13, 11:08 PM by playserver. Edited 2 times in total.)
    Hey guys,
    whenever I try to run trickplay,  it stops working at 62%. I tried looking at the error log, but I don't find the error.
    I am running 10.9.1 on ubuntu 22.04 LTS with docker. I have ffmpeg 6.X installed.
    .txt   jellyfin-ls_logs.txt (Size: 21.47 KB / Downloads: 123)
    2024-05-13, 11:17 PM
    I think you accidentally typed extra numbers in the quality field.
    mjpeg_vaapi @ 0x61f61ed21e00] Invalid quality value 472 (must be 1-100).
    playserver
    2024-05-13, 11:20 PM (This post was last modified: 2024-05-13, 11:30 PM by playserver. Edited 4 times in total.)
    In the trickplay settings there is nothing having the number 472. I added my screenshots https://ibb.co/DkgLJ4m
    https://ibb.co/h91mp4v
    https://ibb.co/pXZ02gL
    Edit: If I select 5 instead of 4 in the Qscale, it gives me the error with 590 instead of 472, with 2 it gives 236
    2024-05-13, 11:42 PM
    Open up /etc/jellyfin/system.xml. What is in this code block for you?
    <TrickplayOptions>
        <EnableHwAcceleration>true</EnableHwAcceleration>
        <EnableHwEncoding>true</EnableHwEncoding>
        <ScanBehavior>NonBlocking</ScanBehavior>
        <ProcessPriority>BelowNormal</ProcessPriority>
        <Interval>10000</Interval>
        <WidthResolutions>
          <int>320</int>
        </WidthResolutions>
        <TileWidth>10</TileWidth>
        <TileHeight>10</TileHeight>
        <Qscale>4</Qscale>
        <JpegQuality>90</JpegQuality>
        <ProcessThreads>2</ProcessThreads>
      </TrickplayOptions>
    playserver
    2024-05-14, 07:49 AM
    <Trickplayoptions>
    <ProcessPriority>Normal</ProcessPriority>
    <WidthResolutions>
    <int>320</int>
    </WidthResolutions>
    <TileWidth>10</Tilewidth>
    <Qscale>4</Qscale>
    <ProcessThreads>1</ProcessThreads>
    2024-05-14, 01:25 PM (This post was last modified: 2024-05-14, 01:25 PM by TheDreadPirate.)
    Can you enable debug logging, restart jellyfin, and restart the trickplay job? Then share the new log.
    https://jellyfin.org/docs/general/admini...ug-logging
    playserver
    2024-05-14, 01:45 PM (This post was last modified: 2024-05-14, 01:45 PM by playserver.)
    I tried to upload the log with the code option but the text is too long. I hope you don't mind the mediafire link.
    https://www.mediafire.com/file/49zs9p6qk...4.log/file
    2024-05-14, 02:54 PM
    I am not seeing the error "Invalid quality value" error message anymore, but it appears that it isn't able to read files in "/data/tvshowsa". The "a" at the end isn't a typo. Can you double check the library path and permissions.
    [2024-05-14 15:38:15.638 +02:00] [INF] [6] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Trickplay generation: "/usr/lib/jellyfin-ffmpeg/ffmpeg -loglevel error -init_hw_device vaapi=va:/dev/dri/renderD128,driver=iHD -noautorotate -i file:\"/data/tvshowsa/[wozzy]SG DL PCM DTS Ssub 1080-10bit 25 OVA(AL)/Steins.Gate.25.OVA.BD.1080p.10bit.DL.PCM.DTS-wozzy.mkv\" -an -sn -vf \"fps=0.10000000149011612,setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,320)/2)*2:trunc(ow/a/2)*2,format=nv12,hwupload_vaapi\" -threads 1 -c:v mjpeg_vaapi -qscale:v 4 -f image2 \"/config/cache/temp/c7d82cca50a84d80bdd022ffa32174df/%08d.jpg\""
    [2024-05-14 15:38:16.229 +02:00] [ERR] [6] Jellyfin.Server.Implementations.Trickplay.TrickplayManager: Error creating trickplay images.
    System.ArgumentException: Can't create trickplay from 0 images.
    IMO, this looks like a permissions/invalid path issue since it affects pretty much everything in /data/tvshowsa.
    playserver
    2024-05-14, 02:58 PM (This post was last modified: 2024-05-14, 03:02 PM by playserver. Edited 1 time in total.)
    tvshowsa is the correct path. The a is added because I have a shows directory for anime and for normal shows. So the normal shows would be tvshow and the anime shows would be tvshowa. I only added trickplay to tvshowsa but I don't think there should be any path issue because everything else works completely fine with this path system. It also adds nfo's to my file system, so I don't know what permission problem it should be. Any ideas what else I could check?
    Edit: Permissions for the folder are set to root. I am however using the following composefrom linuxserver
        container_name: jellyfin-ls
        environment:
          - DOCKER_MODS=linuxserver/mods:jellyfin-opencl-intel
          - PUID=1000
          - PGID=1000
          - TZ=Europe/Berlin
          - JELLYFIN_PublishedServerUrl=192.168.0.5 #optional
          - /home/nas/jellyfin-ls/config:/config
          - /media/ntfs2/jellyfin/Serien:/data/tvshows
          - /media/ntfs3/jellyfin/Serien:/data/tvshows1
          - /media/ntfs2/jellyfin/Anime/Serien:/data/tvshowsa
          - /media/ntfs3/jellyfin/Anime/Serien:/data/tvshowsa1
          - /media/ntfs2/jellyfin/Filme:/data/movies
          - /media/ntfs3/jellyfin/Filme:/data/movies1
          - /media/ntfs2/jellyfin/Anime/Filme:/data/moviesa
          - /media/ntfs3/jellyfin/Anime/Filme:/data/moviesa1
          - /media/ntfs2/jellyfin/Musik:/data/music
          - /media/ntfs3/jellyfin/Musik:/data/music1
        network_mode: 'host'
        restart: unless-stopped
        devices:
          - /dev/dri:/dev/dri
    2024-05-14, 03:19 PM (This post was last modified: 2024-05-14, 03:24 PM by Efficient_Good_5784. Edited 2 times in total.)
    (2024-05-14, 02:58 PM)playserver Wrote: Edit: Permissions for the folder are set to root. I am however using the following composefrom linuxserver
        environment:
          - PUID=1000
          - PGID=1000
          - TZ=Europe/Berlin
        devices:
          - /dev/dri:/dev/dri
    That's your problem. The folder is owned by root, but you set your Jellyfin instance to be under user 1000 and group 1000, which doesn't have access to the folder.
    Either add user & group 1000 to own/have access to the folder, or run your Jellyfin as the root user.
    Root is always set as 0. Change PUID & PGID to 0, or just delete both to have Jellyfin run as root.
