2025-03-09, 04:55 PM
I've been running Jellyfin as a regular install, and had both transcoding and hardware tonemapping enabled.
I decided to switch to docker to make things easier to orchestrate, but I'm having a bit of an issue with hardware tonemapping.
When enabling it, for some reason Jellyfin tries to use OpenCL, which doesn't work.
Running the command to check for vulkan compatibility shows it as being set up correctly, and that ffpmeg in the container is seeing vulkan;
Regular hardware transcode works fine, it's specifically tonemapping that fails.
Here's my Docker Compose file, group 104 is render and the render device is passed through correctly;
Any ideas? I'm totally stumped at this point.
Thanks
/usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -f mov,mp4,m4a,3gp,3g2,mj2 -init_hw_device opencl=ocl:0.0 -filter_hw_device ocl -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:"/media/exodus.mp4" -noautoscale -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -rc_mode VBR -b:v 42805084 -maxrate 42805084 -bufsize 85610168 -profile:v:0 high -sei -a53_cc -force_key_frames:0 "expr:gte(t,n_forced*3)" -vf "setparams=color_primaries=bt2020:color_trc=smpte2084:colorspace=bt2020nc,hwdownload,format=p010le,hwupload=derive_device=opencl,tonemap_opencl=format=nv12:p=bt709:t=bt709:m=bt709:tonemap=bt2390:peak=100:desat=0,hwdownload,format=nv12,hwupload_vaapi" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "0d0ced89159a4038f8259906775d5e97-1.mp4" -start_number 0 -hls_segment_filename "/cache/transcodes/0d0ced89159a4038f8259906775d5e97%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/cache/transcodes/0d0ced89159a4038f8259906775d5e97.m3u8"
libavutil 59. 8.100 / 59. 8.100
libavcodec 61. 3.100 / 61. 3.100
libavformat 61. 1.100 / 61. 1.100
libavdevice 61. 1.100 / 61. 1.100
libavfilter 10. 1.100 / 10. 1.100
libswscale 8. 1.100 / 8. 1.100
libswresample 5. 1.100 / 5. 1.100
libpostproc 58. 1.100 / 58. 1.100
[AVHWDeviceContext @ 0x5d84884f3080] Failed to get number of OpenCL platforms: -1001.
Device creation failed: -19.
Failed to set value 'opencl=ocl:0.0' for option 'init_hw_device': No such device
Error parsing global options: No such deviceRunning the command to check for vulkan compatibility shows it as being set up correctly, and that ffpmeg in the container is seeing vulkan;
docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device vulkan
Splitting the commandline.
Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'.
Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'vulkan'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option v (set logging level) with argument debug.
Applying option init_hw_device (initialise hardware device) with argument vulkan.
[AVHWDeviceContext @ 0x580f822ab6c0] Supported layers:
[AVHWDeviceContext @ 0x580f822ab6c0] VK_LAYER_MESA_device_select
[AVHWDeviceContext @ 0x580f822ab6c0] VK_LAYER_MESA_overlay
[AVHWDeviceContext @ 0x580f822ab6c0] Using instance extension VK_KHR_portability_enumeration
[AVHWDeviceContext @ 0x580f822ab6c0] GPU listing:
[AVHWDeviceContext @ 0x580f822ab6c0] 0: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) (integrated) (0x164e)
[AVHWDeviceContext @ 0x580f822ab6c0] Device 0 selected: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) (integrated) (0x164e)
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_KHR_push_descriptor
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_descriptor_buffer
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_physical_device_drm
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_shader_atomic_float
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_KHR_external_memory_fd
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_external_memory_dma_buf
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_image_drm_format_modifier
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_KHR_external_semaphore_fd
[AVHWDeviceContext @ 0x580f822ab6c0] Using device extension VK_EXT_external_memory_host
[AVHWDeviceContext @ 0x580f822ab6c0] Queue families:
[AVHWDeviceContext @ 0x580f822ab6c0] 0: graphics compute transfer (queues: 1)
[AVHWDeviceContext @ 0x580f822ab6c0] 1: compute transfer (queues: 4)
[AVHWDeviceContext @ 0x580f822ab6c0] 2: sparse (queues: 1)
[AVHWDeviceContext @ 0x580f822ab6c0] Using device: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
[AVHWDeviceContext @ 0x580f822ab6c0] Alignments:
[AVHWDeviceContext @ 0x580f822ab6c0] optimalBufferCopyRowPitchAlignment: 1
[AVHWDeviceContext @ 0x580f822ab6c0] minMemoryMapAlignment: 4096
[AVHWDeviceContext @ 0x580f822ab6c0] nonCoherentAtomSize: 64
[AVHWDeviceContext @ 0x580f822ab6c0] minImportedHostPointerAlignment: 4096
[AVHWDeviceContext @ 0x580f822ab6c0] Using queue family 0 (queues: 1) for graphics
[AVHWDeviceContext @ 0x580f822ab6c0] Using queue family 1 (queues: 4) for compute transfers
Successfully parsed a group of options.
Universal media converter
Use -h to get full help or, even better, run 'man ffmpeg'Regular hardware transcode works fine, it's specifically tonemapping that fails.
image: jellyfin/jellyfin
container_name: jellyfin
user: 103:112
group_add:
- "104"
- "44"
network_mode: host
- /etc/jellyfin:/config
- /var/cache/jellyfin:/cache
- type: bind
source: /media
target: /media
- type: bind
source: /media/fonts
target: /usr/local/share/fonts/custom
read_only: true
devices:
restart: unless-stopped
# Optional - alternative address used for autodiscovery
environment:
- JELLYFIN_PublishedServerUrl=http://example.com
# Optional - may be necessary for docker healthcheck to pass if running in host network mode
extra_hosts:
- host.docker.internal:host-gatewayAny ideas? I'm totally stumped at this point.
Thanks
