    Jellyfin Forum Support Troubleshooting Jellyfin not connecting, mi stick
    Madwish
    2023-11-29, 04:34 PM (This post was last modified: 2023-11-29, 04:35 PM by Madwish.)
    everything worked perfectly until i updated to newest version
    when i open jellyfin(android tv, mi stick) it is not connecting. It will only connect after i run localhost:8096 from server itself.
    if i log in from different pc through ip address it works fine, but still wont work on mi stick
    2023-11-29, 05:14 PM
    Try clearing the app cache on the Mi stick.
    Madwish
    2023-11-30, 11:15 AM
    (2023-11-29, 05:14 PM)TheDreadPirate Wrote: Try clearing the app cache on the Mi stick.
    didn't help sadly. Also reinstalled it just in case, nothing changed
    Serge K
    Country:Ukraine
    2023-11-30, 01:26 PM (This post was last modified: 2023-11-30, 01:28 PM by Serge K. Edited 1 time in total.)
    Your mi stick it is not connecting - what the message you have on the screen?
    Usually after upgrade to new server version you need to reconnect Jellyfin Android Cient to Jellyfin server.
    Madwish
    2023-11-30, 02:33 PM (This post was last modified: 2023-11-30, 04:21 PM by Madwish. Edited 4 times in total.)
    (2023-11-30, 01:26 PM)Serge K Wrote: Your mi stick it is not connecting - what the message you have on the screen?
    unable to connect to server
    wording maybe a bit different depending on where i get it. I had to reconnect anyway, as i deleted the app, but when i tried to reconnect it didn't work, had to log in from server browser first. So i don't think that reconnect is going to help, will check again later
    UPD: not working
    Serge K
    Country:Ukraine
    2023-11-30, 05:04 PM
    ok forget about your stick. Can you check connection to Jellyfin server via any PC (IP_Jellyfin_server:8096)? Does it work?
    Madwish
    2023-12-01, 02:48 AM (This post was last modified: 2023-12-01, 02:48 AM by Madwish.)
    (2023-11-30, 05:04 PM)Serge K Wrote: ok forget about your stick. Can you check connection to Jellyfin server via any PC (IP_Jellyfin_server:8096)? Does it work?
    yes, it works just fine
    Madwish
    2023-12-08, 01:15 PM
    rebooted mi stick and it works fine mostly, sometimes i still can't connect but restarting app or rebooting as last resort helps
    idk why it took me so long to try it
