2024-07-26, 06:54 PM
(This post was last modified: 2024-07-26, 06:56 PM by TheDreadPirate. Edited 1 time in total.)
Can you share your latest docker compose?
Also run this command and share the output.
And also this.
And I see you are using VAAPI instead of Intel Quick Sync. Switch to Quick Sync and make sure you only check boxes that your CPU supports.
https://en.wikipedia.org/wiki/Intel_Quic...d_encoding
The Coffee Lake column.
sudo docker exec jellyfin env
And also this.
sudo cat /media/data/jellyfin/config/config/encoding.xml
Jellyfin 10.9.11
Ubuntu 24.04 LTS (bare metal)
Intel i3 12100 on Asus Prime H610M-E D4 mATX
32GB DDR4-3600
WD Green 3TB (Samba shares)
WD Red 3TB CMR (WIP Media, Test libraries)
Fractal Meshify 2
Corsair CX430
32GB DDR4-3600
Fractal Meshify 2
Corsair CX430
