    Jellyfin Forum Support General Questions Problem start jellybin
    Pages (3): 1 2 3 Next »
    Paro89
    2025-04-10, 04:37 AM
    Good morning. For about a week jellybin you upload to me as in the screenshot and I have no chance to do anything. I can not see the covers, I can not update the libraries, I can not understand anything. I was hoping that in a few days it would settle down, but nothing. I have the latest version for ubuntu.
    2025-04-10, 12:43 PM
    Can you share your jellyfin logs via privatebin.net?
    /var/log/jellyfin/log_20250410.log
    Paro89
    2025-04-10, 02:00 PM
    I only see log_20250227. I have no other log.
    https://privatebin.net/?0cf1f53d135b2969...G97nrRh5H3
    I hope it is all correct.
    2025-04-10, 03:19 PM (This post was last modified: 2025-04-10, 03:20 PM by TheDreadPirate.)
    Have you not been able to start Jellyfin since February?
    sudo systemctl status jellyfin
    Or did you switch to docker?
    Also, your log was empty. Sooooo, not much to work with.
    Share the output of this command.
    sudo journalctl -u jellyfin -n 500 --no-pager
    Paro89
    2025-04-10, 04:37 PM
    apr 08 07:14:17 paro-PC systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    apr 08 07:14:17 paro-PC (jellyfin)[7685]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Jellyfin version: 10.10.7
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Environment Variables: ["[JELLYFIN_USER, jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]"]
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Operating system: Ubuntu 24.04.2 LTS
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Architecture: X64
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] 64-Bit Process: True
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] User Interactive: True
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Processor count: 12
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Program data path: /var/lib/jellyfin
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Log directory path: /var/log/jellyfin
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Config directory path: /etc/jellyfin
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Cache path: /var/cache/jellyfin
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Temp directory path: /tmp/jellyfin
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Web resources path: /usr/share/jellyfin/web
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [INF] Application directory: /usr/lib/jellyfin/bin/
    apr 08 07:14:17 paro-PC jellyfin[7685]: [07:14:17] [ERR] The server is expected to host the web client, but the provided content directory is either invalid or empty: /usr/share/jellyfin/web. If you do not want to host the web client with the server, you may set the '--nowebclient' command line flag, or set'hostwebclient=false' in your config settings
    apr 08 07:14:17 paro-PC systemd[1]: jellyfin.service: Main process exited, code=exited, status=1/FAILURE
    apr 08 07:14:17 paro-PC systemd[1]: jellyfin.service: Failed with result 'exit-code'.
    apr 08 07:14:18 paro-PC systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 1.
    apr 08 07:14:18 paro-PC systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    apr 08 07:14:18 paro-PC (jellyfin)[7730]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Jellyfin version: 10.10.7
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Environment Variables: ["[JELLYFIN_USER, jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]"]
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Operating system: Ubuntu 24.04.2 LTS
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Architecture: X64
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] 64-Bit Process: True
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] User Interactive: True
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Processor count: 12
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Program data path: /var/lib/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Log directory path: /var/log/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Config directory path: /etc/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Cache path: /var/cache/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Temp directory path: /tmp/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Web resources path: /usr/share/jellyfin/web
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [INF] Application directory: /usr/lib/jellyfin/bin/
    apr 08 07:14:18 paro-PC jellyfin[7730]: [07:14:18] [ERR] The server is expected to host the web client, but the provided content directory is either invalid or empty: /usr/share/jellyfin/web. If you do not want to host the web client with the server, you may set the '--nowebclient' command line flag, or set'hostwebclient=false' in your config settings
    apr 08 07:14:18 paro-PC systemd[1]: jellyfin.service: Main process exited, code=exited, status=1/FAILURE
    apr 08 07:14:18 paro-PC systemd[1]: jellyfin.service: Failed with result 'exit-code'.
    apr 08 07:14:18 paro-PC systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 2.
    apr 08 07:14:18 paro-PC (jellyfin)[7744]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Jellyfin version: 10.10.7
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Environment Variables: ["[JELLYFIN_USER, jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]"]
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Operating system: Ubuntu 24.04.2 LTS
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Architecture: X64
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] 64-Bit Process: True
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] User Interactive: True
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Processor count: 12
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Program data path: /var/lib/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Log directory path: /var/log/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Config directory path: /etc/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Cache path: /var/cache/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Temp directory path: /tmp/jellyfin
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Web resources path: /usr/share/jellyfin/web
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [INF] Application directory: /usr/lib/jellyfin/bin/
    apr 08 07:14:18 paro-PC jellyfin[7744]: [07:14:18] [ERR] The server is expected to host the web client, but the provided content directory is either invalid or empty: /usr/share/jellyfin/web. If you do not want to host the web client with the server, you may set the '--nowebclient' command line flag, or set'hostwebclient=false' in your config settings
    apr 08 07:14:19 paro-PC systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 3.
    apr 08 07:14:19 paro-PC systemd[1]: Started jellyfin.service - Jellyfin Media Server.
    apr 08 07:14:19 paro-PC (jellyfin)[7767]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Jellyfin version: 10.10.7
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Environment Variables: ["[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_USER, jellyfin]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]"]
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Operating system: Ubuntu 24.04.2 LTS
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Architecture: X64
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] 64-Bit Process: True
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] User Interactive: True
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Processor count: 12
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Program data path: /var/lib/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Log directory path: /var/log/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Config directory path: /etc/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Cache path: /var/cache/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Temp directory path: /tmp/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Web resources path: /usr/share/jellyfin/web
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [INF] Application directory: /usr/lib/jellyfin/bin/
    apr 08 07:14:19 paro-PC jellyfin[7767]: [07:14:19] [ERR] The server is expected to host the web client, but the provided content directory is either invalid or empty: /usr/share/jellyfin/web. If you do not want to host the web client with the server, you may set the '--nowebclient' command line flag, or set'hostwebclient=false' in your config settings
    apr 08 07:14:19 paro-PC systemd[1]: jellyfin.service: Main process exited, code=exited, status=1/FAILURE
    apr 08 07:14:19 paro-PC systemd[1]: jellyfin.service: Failed with result 'exit-code'.
    apr 08 07:14:19 paro-PC systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 4.
    apr 08 07:14:19 paro-PC (jellyfin)[7788]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Jellyfin version: 10.10.7
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Environment Variables: ["[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS --datadir $JELLYFIN_DATA_DIR --configdir $JELLYFIN_CONFIG_DIR --logdir $JELLYFIN_LOG_DIR --cachedir $JELLYFIN_CACHE_DIR]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_USER, jellyfin]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_ADDITIONAL_OPTS, ]"]
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Operating system: Ubuntu 24.04.2 LTS
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Architecture: X64
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] 64-Bit Process: True
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] User Interactive: True
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Processor count: 12
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Program data path: /var/lib/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Log directory path: /var/log/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Config directory path: /etc/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Cache path: /var/cache/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Temp directory path: /tmp/jellyfin
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Web resources path: /usr/share/jellyfin/web
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [INF] Application directory: /usr/lib/jellyfin/bin/
    apr 08 07:14:19 paro-PC jellyfin[7788]: [07:14:19] [ERR] The server is expected to host the web client, but the provided content directory is either invalid or empty: /usr/share/jellyfin/web. If you do not want to host the web client with the server, you may set the '--nowebclient' command line flag, or set'hostwebclient=false' in your config settings
    apr 08 07:14:20 paro-PC systemd[1]: jellyfin.service: Scheduled restart job, restart counter is at 5.
    apr 08 07:14:20 paro-PC systemd[1]: jellyfin.service: Start request repeated too quickly.
    apr 08 07:14:20 paro-PC systemd[1]: jellyfin.service: Failed with result 'exit-code'.
    apr 08 07:14:20 paro-PC systemd[1]: Failed to start jellyfin.service - Jellyfin Media Server.
    Before i used Plex. i installed Jellifyn recently.
    2025-04-10, 05:38 PM
    How did you install Jellyfin?
    Can you share the output of this command?
    sudo apt list --installed | grep jellyfin
    Paro89
    2025-04-11, 05:21 AM
    WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
    I installed it with "software" application of Ubuntu.
    Paro89
    2025-04-11, 05:57 AM (This post was last modified: 2025-04-11, 05:59 AM by Paro89. Edited 1 time in total.)
    (2025-04-10, 12:43 PM)TheDreadPirate Wrote: Can you share your jellyfin logs via privatebin.net?
    i tried to reinstall it. This is the output's link:
    https://privatebin.net/?c1ca26bbc0411a88#Dm3UKsLDz92usyYdPFMKacMGqa1oWtKEdVzPDZ9CBRy5
    (2025-04-10, 05:38 PM)TheDreadPirate Wrote: Can you share the output of this command?
    jellyfin-ffmpeg7/sconosciuto,now 7.0.2-9-noble amd64 [installato, automatico]
    jellyfin-server/sconosciuto,now 10.10.7+ubu2404 amd64 [installato, automatico]
    jellyfin-web/sconosciuto,now 10.10.7+ubu2404 all [installato, automatico]
    jellyfin/sconosciuto,now 10.10.7+ubu2404 all [installato]
    2025-04-11, 11:03 AM
    You have to remove the version you installed from Ubuntu's app store. It is a flatpak, which we don't recommend using if you can avoid it, and is running in the background and preventing the apt package install of Jellyfin from running.
    Once you've removed the "store" version of Jellyfin, you will need to restart the Jellyfin service.
    sudo systemctl restart jellyfin
    Then you will need to open port 8096, 7359, and 1900.
    sudo ufw enable
    sudo ufw allow 8096/tcp
    sudo ufw allow 7359/udp
    sudo ufw allow 1900/udp
    Paro89
    2025-04-11, 11:10 AM
    I did it. And now for start Jellyfin? The icon is desappear now.
