    Jellyfin Forum Support Troubleshooting Problem with 7.1 TrueHD
    woodsworth
    2024-02-11, 12:52 PM (This post was last modified: 2024-02-11, 12:52 PM by woodsworth. Edited 1 time in total.)
    This is a strange one I do not understand.
    Devices in question are an M1 iPad Pro 3rd generation and an LG OLED C1. I have used both the iPad app and the WebOS app as well as the browser on both devices. The video I have an issue with is The Last Of Us, all episodes do not have audio when watching through the app on both devices. It does however have audio when watching on the web version on both.
    I have 3 4K films which have the same audio codec of 7.1 TrueHD and they all work with audio in the apps and on the web browser. I have enabled some options that I've seen when browsing but cannot for the life of me get it working.
    If anyone has any suggestions I would be greatful. Some further details, the Server app is on the latest version (10.8.13-1) and is running Ubuntu 22.04.3 LTS. If any more information is needed including logs, let me know. What is strange as well is when watching it on the WebOS app, and checking the I from the dashboard, it reports as being fully supported with no modifications but when watching through a browser on the TV, it says it has an incompatible audio format or number channels and only the audio stream will be transcoded.
    Thanks.
    2024-02-11, 05:57 PM
    Which iOS client are you using? Besides the browser.
    woodsworth
    2024-02-14, 11:35 AM
    I am using the Swiftfin app from the App Store which is on the latest version and iPadOS version 17.3.
    If you need anymore information, let me know.
    2024-02-14, 06:37 PM
    Replicate the problem and share your jellyfin and ffmpeg log.
    woodsworth
    2024-02-17, 11:33 AM (This post was last modified: 2024-02-17, 11:34 AM by woodsworth.)
    Here’s the ffmpeg log:
    /videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/534.mp4
    {"Protocol":0,"Id":"659af5412a818b7768195870c5394888","Path":"/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv,webm","Size":8191327744,"Name":"S01E01","IsRemote":false,"ETag":"8cd6bab1027ca2e75be30a1065b784f4","RunTimeTicks":48500129792,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"h264","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":"bt709","ColorTransfer":"bt709","ColorPrimaries":"bt709","DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":"SDR","VideoRangeType":"SDR","VideoDoViTitle":null,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"DisplayTitle":"1080p H264 SDR","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"ChannelLayout":null,"BitRate":13511432,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main","Type":1,"AspectRatio":"16:9","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":null},{"Codec":"truehd","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Surround 7.1","VideoRange":null,"VideoRangeType":null,"VideoDoViTitle":null,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"DisplayTitle":"Surround 7.1 - English - TRUEHD - Default","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":"7.1","BitRate":null,"BitDepth":24,"RefFrames":null,"PacketLength":null,"Channels":8,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":13511432,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":null,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -ss 00:53:24.000 -noaccurate_seek -fflags +genpts -f matroska,webm -i file:"/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 6 -ab 640000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type fmp4 -hls_fmp4_init_filename "64ae7322e76997a0b0b6e2f530288e50-1.mp4" -start_number 534 -hls_segment_filename "/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8"
    ffmpeg version 5.1.4-Jellyfin Copyright © 2000-2023 the FFmpeg developers
    configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-libs=-lfftw3f --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-libdrm --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libsvtav1 --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-opencl --enable-vaapi --enable-amf --enable-libmfx --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    libavutil 57. 28.100 / 57. 28.100
    libavcodec 59. 37.100 / 59. 37.100
    libavformat 59. 27.100 / 59. 27.100
    libavdevice 59. 7.100 / 59. 7.100
    libavfilter 8. 44.100 / 8. 44.100
    libswscale 6. 7.100 / 6. 7.100
    libswresample 4. 7.100 / 4. 7.100
    libpostproc 56. 6.100 / 56. 6.100
    [h264 @ 0x562fc9af8c00] Increasing reorder buffer to 2
    Input #0, matroska,webm, from 'fileConfused-facemedia/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4':
    Metadata:
    title : S01E01
    creation_time : 2024-01-21T22:17:31.000000Z
    ENCODER : Lavf60.16.100
    Duration: 01:20:50.01, start: 0.000000, bitrate: 13511 kb/s
    Chapters:
    Chapter #0:0: start 0.000000, end 269.060000
    Metadata:
    title : Chapter 1
    Chapter #0:1: start 269.060000, end 765.265000
    Metadata:
    title : Chapter 2
    Chapter #0:2: start 765.265000, end 1260.468000
    Metadata:
    title : Chapter 3
    Chapter #0:3: start 1260.468000, end 1807.681000
    Metadata:
    title : Chapter 4
    Chapter #0:4: start 1807.681000, end 2381.254000
    Metadata:
    title : Chapter 5
    Chapter #0:5: start 2381.254000, end 2865.613000
    Metadata:
    title : Chapter 6
    Chapter #0:6: start 2865.613000, end 3435.349000
    Metadata:
    title : Chapter 7
    Chapter #0:7: start 3435.349000, end 3909.072000
    Metadata:
    title : Chapter 8
    Chapter #0:8: start 3909.072000, end 4426.881000
    Metadata:
    title : Chapter 9
    Chapter #0:9: start 4426.881000, end 4772.977000
    Metadata:
    title : Chapter 10
    Chapter #0:10: start 4772.977000, end 4849.970000
    Metadata:
    title : Chapter 11
    Stream #0:0: Video: h264 (Main), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default)
    Metadata:
    DURATION : 01:20:50.012000000
    Stream #0:1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (24 bit) (default)
    Metadata:
    title : Surround 7.1
    DURATION : 01:20:50.013000000
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Stream #0:1 -> #0:1 (truehd (native) -> aac (libfdk_aac))
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50-1.mp4' for writing
    Output #0, hls, to '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8':
    Metadata:
    encoder : Lavf59.27.100
    Stream #0:0: Video: h264 (Main), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 24k tbn (default)
    Stream #0:1: Audio: aac, 48000 Hz, 5.1, s16, 640 kb/s (default)
    Metadata:
    encoder : Lavc59.37.100 libfdk_aac
    frame= 1 fps=0.0 q=-1.0 size=N/A time=-00:53:22.86 bitrate=N/A speed=N/A
    frame= 104 fps=0.0 q=-1.0 size=N/A time=00:00:04.24 bitrate=N/A speed=8.25x
    frame= 209 fps=206 q=-1.0 size=N/A time=00:00:08.66 bitrate=N/A speed=8.53x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50534.mp4' for writing
    frame= 305 fps=201 q=-1.0 size=N/A time=00:00:12.67 bitrate=N/A speed=8.36x
    frame= 409 fps=203 q=-1.0 size=N/A time=00:00:16.96 bitrate=N/A speed=8.41x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50535.mp4' for writing
    frame= 504 fps=200 q=-1.0 size=N/A time=00:00:20.93 bitrate=N/A speed=8.32x
    frame= 606 fps=201 q=-1.0 size=N/A time=00:00:25.21 bitrate=N/A speed=8.36x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50536.mp4' for writing
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50537.mp4' for writing
    frame= 700 fps=199 q=-1.0 size=N/A time=00:00:29.12 bitrate=N/A speed=8.28x
    frame= 801 fps=199 q=-1.0 size=N/A time=00:00:33.32 bitrate=N/A speed= 8.3x
    frame= 904 fps=200 q=-1.0 size=N/A time=00:00:37.61 bitrate=N/A speed=8.33x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50538.mp4' for writing
    frame= 1000 fps=199 q=-1.0 size=N/A time=00:00:41.62 bitrate=N/A speed= 8.3x
    frame= 1106 fps=200 q=-1.0 size=N/A time=00:00:46.06 bitrate=N/A speed=8.35x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50539.mp4' for writing
    frame= 1203 fps=200 q=-1.0 size=N/A time=00:00:50.11 bitrate=N/A speed=8.33x
    frame= 1310 fps=201 q=-1.0 size=N/A time=00:00:54.57 bitrate=N/A speed=8.37x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50540.mp4' for writing
    frame= 1410 fps=201 q=-1.0 size=N/A time=00:00:58.75 bitrate=N/A speed=8.36x
    frame= 1516 fps=201 q=-1.0 size=N/A time=00:01:03.15 bitrate=N/A speed=8.39x
    frame= 1621 fps=202 q=-1.0 size=N/A time=00:01:07.54 bitrate=N/A speed=8.41x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50541.mp4' for writing
    frame= 1720 fps=202 q=-1.0 size=N/A time=00:01:11.66 bitrate=N/A speed= 8.4x
    frame= 1826 fps=202 q=-1.0 size=N/A time=00:01:16.09 bitrate=N/A speed=8.43x
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50542.mp4' for writing
    frame= 1925 fps=202 q=-1.0 size=N/A time=00:01:20.21 bitrate=N/A speed=8.42x
    [q] command received. Exiting.
    [hls @ 0x562fc9c5ac40] Opening '/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50543.mp4' for writing
    frame= 2004 fps=202 q=-1.0 Lsize=N/A time=00:01:23.54 bitrate=N/A speed=8.42x
    video:103277kB audio:6528kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
    And the Jellyfin log:
    [2024-02-17 10:03:49.520 +00:00] [INF] Jellyfin version: "10.8.13"
    [2024-02-17 10:03:49.785 +00:00] [INF] Environment Variables: ["[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[JELLYFIN_ADDITIONAL_OPTS, ]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_ARGS, $JELLYFIN_WEB_OPT $JELLYFIN_RESTART_OPT $JELLYFIN_FFMPEG_OPT $JELLYFIN_SERVICE_OPT $JELLYFIN_NOWEBAPP_OPT $JELLFIN_ADDITIONAL_OPTS]", "[JELLYFIN_USER, jellyfin]", "[JELLYFIN_WEB_OPT, --webdir=/usr/share/jellyfin/web]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]", "[JELLYFIN_RESTART_OPT, --restartpath=/usr/lib/jellyfin/restart.sh]", "[JELLYFIN_FFMPEG_OPT, --ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg]"]
    [2024-02-17 10:03:49.791 +00:00] [INF] Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--webdir=/usr/share/jellyfin/web", "--restartpath=/usr/lib/jellyfin/restart.sh", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    [2024-02-17 10:03:49.793 +00:00] [INF] Operating system: "Linux"
    [2024-02-17 10:03:49.793 +00:00] [INF] Architecture: X64
    [2024-02-17 10:03:49.795 +00:00] [INF] 64-Bit Process: True
    [2024-02-17 10:03:49.795 +00:00] [INF] User Interactive: True
    [2024-02-17 10:03:49.795 +00:00] [INF] Processor count: 16
    [2024-02-17 10:03:49.795 +00:00] [INF] Program data path: "/var/lib/jellyfin"
    [2024-02-17 10:03:49.795 +00:00] [INF] Web resources path: "/usr/share/jellyfin/web"
    [2024-02-17 10:03:49.795 +00:00] [INF] Application directory: "/usr/lib/jellyfin/bin/"
    [2024-02-17 10:03:50.613 +00:00] [INF] Setting cache path: "/var/cache/jellyfin"
    [2024-02-17 10:03:50.705 +00:00] [INF] Loading assemblies
    [2024-02-17 10:03:51.118 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 10:03:51.119 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 10:03:51.122 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 10:03:51.139 +00:00] [INF] Using bind addresses: "[]"
    [2024-02-17 10:03:51.139 +00:00] [INF] Using bind exclusions: "[]"
    [2024-02-17 10:03:53.388 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 10:03:53.389 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 10:03:53.390 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 10:04:00.847 +00:00] [INF] Loaded plugin: "TMDb" "10.8.13.0"
    [2024-02-17 10:04:00.849 +00:00] [INF] Loaded plugin: "Studio Images" "10.8.13.0"
    [2024-02-17 10:04:00.851 +00:00] [INF] Loaded plugin: "OMDb" "10.8.13.0"
    [2024-02-17 10:04:00.852 +00:00] [INF] Loaded plugin: "MusicBrainz" "10.8.13.0"
    [2024-02-17 10:04:00.853 +00:00] [INF] Loaded plugin: "AudioDB" "10.8.13.0"
    [2024-02-17 10:04:01.050 +00:00] [INF] Kestrel listening on "Any IP4 Address"
    [2024-02-17 10:04:02.002 +00:00] [INF] Running startup tasks
    [2024-02-17 10:04:02.130 +00:00] [INF] Daily trigger for "Extract Chapter Images" set to fire at 2024-02-18 02:00:00.000 +00:00, which is 15:55:57.8699887 from now.
    [2024-02-17 10:04:02.380 +00:00] [INF] Found ffmpeg version "5.1.4"
    [2024-02-17 10:04:02.484 +00:00] [INF] Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
    [2024-02-17 10:04:02.528 +00:00] [INF] Available "encoders": ["libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [2024-02-17 10:04:02.578 +00:00] [INF] Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
    [2024-02-17 10:04:02.827 +00:00] [INF] Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
    [2024-02-17 10:04:03.136 +00:00] [INF] FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
    [2024-02-17 10:04:03.139 +00:00] [INF] ServerId: "2dadf3614cfa4245af9cf2acb867822b"
    [2024-02-17 10:04:03.412 +00:00] [INF] Executed all pre-startup entry points in 0:00:00.2485449
    [2024-02-17 10:04:03.413 +00:00] [INF] Core startup complete
    [2024-02-17 10:04:04.134 +00:00] [INF] Watching directory "/media/hdd/Plex/My Movies"
    [2024-02-17 10:04:04.138 +00:00] [INF] Watching directory "/media/hdd/Plex/Films"
    [2024-02-17 10:04:04.140 +00:00] [INF] Executed all post-startup entry points in 0:00:00.7270452
    [2024-02-17 10:04:04.141 +00:00] [INF] Startup complete 0:00:15.3193945
    [2024-02-17 10:04:04.146 +00:00] [INF] Watching directory "/media/hdd/Plex/TV Shows"
    [2024-02-17 10:04:04.147 +00:00] [INF] Watching directory "/media/hdd/Plex/Pictures and Videos"
    [2024-02-17 10:04:04.147 +00:00] [INF] Watching directory "/media/hdd/Plex/My TV Shows"
    [2024-02-17 10:04:04.147 +00:00] [INF] Watching directory "/media/hdd/Plex/Anime"
    [2024-02-17 10:04:05.151 +00:00] [INF] "StartupTrigger" fired for task: "Update Plugins"
    [2024-02-17 10:04:05.155 +00:00] [INF] Queuing task "PluginUpdateTask"
    [2024-02-17 10:04:05.164 +00:00] [INF] Executing "Update Plugins"
    [2024-02-17 10:04:06.439 +00:00] [INF] "Update Plugins" Completed after 0 minute(s) and 1 seconds
    [2024-02-17 10:04:06.459 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.126 +00:00] [INF] "IntervalTrigger" fired for task: "Download missing subtitles"
    [2024-02-17 10:05:02.126 +00:00] [INF] Queuing task "SubtitleScheduledTask"
    [2024-02-17 10:05:02.126 +00:00] [INF] Executing "Download missing subtitles"
    [2024-02-17 10:05:02.133 +00:00] [INF] "IntervalTrigger" fired for task: "Clean Cache Directory"
    [2024-02-17 10:05:02.133 +00:00] [INF] "IntervalTrigger" fired for task: "Clean Log Directory"
    [2024-02-17 10:05:02.133 +00:00] [INF] Queuing task "DeleteLogFileTask"
    [2024-02-17 10:05:02.133 +00:00] [INF] Queuing task "DeleteCacheFileTask"
    [2024-02-17 10:05:02.133 +00:00] [INF] Executing "Clean Log Directory"
    [2024-02-17 10:05:02.136 +00:00] [INF] Executing "Clean Cache Directory"
    [2024-02-17 10:05:02.136 +00:00] [INF] "IntervalTrigger" fired for task: "Clean Transcode Directory"
    [2024-02-17 10:05:02.136 +00:00] [INF] "IntervalTrigger" fired for task: "Optimize database"
    [2024-02-17 10:05:02.136 +00:00] [INF] Queuing task "OptimizeDatabaseTask"
    [2024-02-17 10:05:02.136 +00:00] [INF] Executing "Optimize database"
    [2024-02-17 10:05:02.136 +00:00] [INF] Queuing task "DeleteTranscodeFileTask"
    [2024-02-17 10:05:02.137 +00:00] [INF] Executing "Clean Transcode Directory"
    [2024-02-17 10:05:02.137 +00:00] [INF] Optimizing and vacuuming jellyfin.db...
    [2024-02-17 10:05:02.139 +00:00] [INF] "Download missing subtitles" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.140 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.140 +00:00] [INF] "Clean Log Directory" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.181 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.221 +00:00] [INF] "IntervalTrigger" fired for task: "Scan Media Library"
    [2024-02-17 10:05:02.221 +00:00] [INF] "IntervalTrigger" fired for task: "TasksRefreshChannels"
    [2024-02-17 10:05:02.221 +00:00] [INF] Queuing task "RefreshMediaLibraryTask"
    [2024-02-17 10:05:02.221 +00:00] [INF] "IntervalTrigger" fired for task: "Refresh Guide"
    [2024-02-17 10:05:02.221 +00:00] [INF] Queuing task "RefreshChannelsScheduledTask"
    [2024-02-17 10:05:02.221 +00:00] [INF] Queuing task "RefreshGuideScheduledTask"
    [2024-02-17 10:05:02.221 +00:00] [INF] Executing "Scan Media Library"
    [2024-02-17 10:05:02.221 +00:00] [INF] Executing "Refresh Guide"
    [2024-02-17 10:05:02.222 +00:00] [INF] "Clean Transcode Directory" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.222 +00:00] [INF] Executing "TasksRefreshChannels"
    [2024-02-17 10:05:02.223 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.266 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/Pictures and Videos"
    [2024-02-17 10:05:02.267 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/Films"
    [2024-02-17 10:05:02.268 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/Anime"
    [2024-02-17 10:05:02.269 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/TV Shows"
    [2024-02-17 10:05:02.269 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/My Movies"
    [2024-02-17 10:05:02.270 +00:00] [INF] Stopping directory watching for path "/media/hdd/Plex/My TV Shows"
    [2024-02-17 10:05:02.274 +00:00] [INF] Validating media library
    [2024-02-17 10:05:02.279 +00:00] [INF] "TasksRefreshChannels" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.280 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.375 +00:00] [INF] "Clean Cache Directory" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.376 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:02.512 +00:00] [INF] jellyfin.db optimized successfully!
    [2024-02-17 10:05:02.512 +00:00] [INF] "Optimize database" Completed after 0 minute(s) and 0 seconds
    [2024-02-17 10:05:02.513 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:05.494 +00:00] [INF] Refreshing guide with 7 days of guide data
    [2024-02-17 10:05:05.545 +00:00] [INF] "Refresh Guide" Completed after 0 minute(s) and 3 seconds
    [2024-02-17 10:05:05.546 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:42.240 +00:00] [INF] Creating image collage and saving to "/var/cache/jellyfin/temp/a21c70100ceb48d4a86b467e46c0472a.png"
    [2024-02-17 10:05:43.711 +00:00] [INF] Completed creation of image collage and saved to "/var/cache/jellyfin/temp/a21c70100ceb48d4a86b467e46c0472a.png"
    [2024-02-17 10:05:45.096 +00:00] [INF] Watching directory "/media/hdd/Plex/My Movies"
    [2024-02-17 10:05:45.099 +00:00] [INF] Watching directory "/media/hdd/Plex/Anime"
    [2024-02-17 10:05:45.099 +00:00] [INF] "Scan Media Library" Completed after 0 minute(s) and 42 seconds
    [2024-02-17 10:05:45.099 +00:00] [INF] Watching directory "/media/hdd/Plex/My TV Shows"
    [2024-02-17 10:05:45.101 +00:00] [INF] ExecuteQueuedTasks
    [2024-02-17 10:05:45.315 +00:00] [INF] Watching directory "/media/hdd/Plex/Films"
    [2024-02-17 10:05:45.319 +00:00] [INF] Watching directory "/media/hdd/Plex/TV Shows"
    [2024-02-17 10:05:45.324 +00:00] [INF] Watching directory "/media/hdd/Plex/Pictures and Videos"
    [2024-02-17 11:06:27.342 +00:00] [INF] "My Movies" ("/media/hdd/Plex/My Movies") will be refreshed.
    [2024-02-17 11:07:36.469 +00:00] [INF] "Films" ("/media/hdd/Plex/Films") will be refreshed.
    [2024-02-17 11:10:03.523 +00:00] [INF] "Anime" ("/media/hdd/Plex/Anime") will be refreshed.
    [2024-02-17 11:16:55.160 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:16:55.160 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 11:16:55.160 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:16:57.167 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:16:57.167 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 11:16:57.167 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:16:59.172 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:16:59.172 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 11:16:59.172 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:17:01.178 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:17:01.178 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 11:17:01.178 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:17:03.185 +00:00] [INF] Defined LAN addresses : "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:17:03.185 +00:00] [INF] Defined LAN exclusions : "[]"
    [2024-02-17 11:17:03.185 +00:00] [INF] Using LAN addresses: "[10.0.0.0/8,IP Address,IP Address/16]"
    [2024-02-17 11:19:54.134 +00:00] [WRN] Slow HTTP Response from "http://127.0.0.1Port/Branding/Css" to "127.0.0.1" in 0:00:01.0030977 with Status Code 200
    [2024-02-17 11:19:54.158 +00:00] [WRN] Slow HTTP Response from "http://127.0.0.1Port/system/info/public" to "127.0.0.1" in 0:00:00.8352974 with Status Code 200
    [2024-02-17 11:19:55.214 +00:00] [WRN] Slow HTTP Response from "http://127.0.0.1Port/System/Info" to "127.0.0.1" in 0:00:00.9884114 with Status Code 200
    [2024-02-17 11:19:55.354 +00:00] [INF] WS "127.0.0.1" request
    [2024-02-17 11:19:55.700 +00:00] [WRN] The entity type '"AccessSchedule"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.700 +00:00] [WRN] The entity type '"ActivityLog"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"CustomItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"DisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"HomeSection"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"ImageInfo"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"ItemDisplayPreferences"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"Permission"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"Preference"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"ApiKey"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"Device"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"DeviceOptions"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.701 +00:00] [WRN] The entity type '"User"' is configured to use schema '"jellyfin"', but SQLite does not support schemas. This configuration will be ignored by the SQLite provider.
    [2024-02-17 11:19:55.946 +00:00] [WRN] Slow HTTP Response from "http://127.0.0.1Port/Sessions/Capabilities/Full" to "127.0.0.1" in 0:00:00.6289701 with Status Code 204
    [2024-02-17 11:19:56.069 +00:00] [WRN] Slow HTTP Response from "http://127.0.0.1Port/DisplayPreferences/usersettings?userId=9518f8219089493195903e064cfeb604&client=emby" to "127.0.0.1" in 0:00:00.7516622 with Status Code 200
    [2024-02-17 11:21:57.558 +00:00] [INF] WS "" request
    [2024-02-17 11:21:58.993 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Items/0e4979d3a1f3b2797cf57cc58ed03aeb/Images/Primary?fillHeight=556&fillWidth=370&quality=96&tag=982fbf448aa812aec1cfe34d890b860a" to "" in 0:00:00.5283995 with Status Code 200
    [2024-02-17 11:22:11.396 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Items/ca853c88b1601959ccbbf2c97c6cce37/Images/Primary?fillHeight=896&fillWidth=597&quality=96&tag=f8fc45d45765a0914f4e982a67a16594" to "IP Address" in 0:00:00.548659 with Status Code 200
    [2024-02-17 11:22:23.473 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Items/8bbe53fdad2ff28bb8559d93a0bb0867/Images/Primary?fillHeight=896&fillWidth=597&quality=96&tag=7f6735c267ed1325b65998e07228cbb0" to "IP Address" in 0:00:00.5451916 with Status Code 200
    [2024-02-17 11:22:24.758 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:22:24.932 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=Transcode, TranscodeReason=ContainerNotSupported, AudioCodecNotSupported ) "mediaConfused-facevideos/659af541-2a81-8b77-6819-5870c5394888/master.m3u8?MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&api_key=<token>&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported"
    [2024-02-17 11:22:25.908 +00:00] [INF] Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
    [2024-02-17 11:22:25.954 +00:00] [INF] "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-analyzeduration 200M -fflags +genpts -f matroska,webm -i file:\"/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 6 -ab 640000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type fmp4 -hls_fmp4_init_filename \"64ae7322e76997a0b0b6e2f530288e50-1.mp4\" -start_number 0 -hls_segment_filename \"/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50%d.mp4\" -hls_playlist_type vod -hls_list_size 0 -y \"/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8\""
    [2024-02-17 11:22:28.278 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/-1.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=0&actualSegmentLengthTicks=0" to "IP Address" in 0:00:02.4053447 with Status Code 200
    [2024-02-17 11:22:28.766 +00:00] [INF] Stopping ffmpeg process with q command for "/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8"
    [2024-02-17 11:22:28.886 +00:00] [INF] FFmpeg exited with code 0
    [2024-02-17 11:22:28.888 +00:00] [INF] Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
    [2024-02-17 11:22:28.889 +00:00] [INF] "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-analyzeduration 200M -ss 00:53:24.000 -noaccurate_seek -fflags +genpts -f matroska,webm -i file:\"/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -start_at_zero -codec:a:0 libfdk_aac -ac 6 -ab 640000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 6 -hls_segment_type fmp4 -hls_fmp4_init_filename \"64ae7322e76997a0b0b6e2f530288e50-1.mp4\" -start_number 534 -hls_segment_filename \"/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50%d.mp4\" -hls_playlist_type vod -hls_list_size 0 -y \"/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8\""
    [2024-02-17 11:22:31.517 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/534.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32040000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:02.7742829 with Status Code 200
    [2024-02-17 11:22:33.677 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/537.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32220000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:00.7062435 with Status Code 200
    [2024-02-17 11:22:34.909 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/538.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32280000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:01.1030437 with Status Code 200
    [2024-02-17 11:22:36.098 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/539.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32340000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:00.7039449 with Status Code 200
    [2024-02-17 11:22:37.234 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/540.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32400000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:00.5052672 with Status Code 200
    [2024-02-17 11:22:38.478 +00:00] [WRN] Slow HTTP Response from "http://IP Address/videos/659af541-2a81-8b77-6819-5870c5394888/hls1/main/541.mp4?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTVfNykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzE3LjIgU2FmYXJpLzYwNS4xLjE1fDE3MDc2NTI3NjY4MjY1&MediaSourceId=659af5412a818b7768195870c5394888&VideoCodec=hevc,h264,h264&AudioCodec=aac,ac3,eac3,flac,alac&AudioStreamIndex=1&VideoBitrate=139360000&AudioBitrate=640000&MaxFramerate=23.976025&PlaySessionId=2ca630d8e78f4d40b401653079fd1e94&api_key=024633ce4d9648498250cfd3950e32cc&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&RequireAvc=false&Tag=8cd6bab1027ca2e75be30a1065b784f4&SegmentContainer=mp4&MinSegments=2&BreakOnNonKeyFrames=True&h264-level=40&h264-videobitdepth=8&h264-profile=main&h264-rangetype=SDR&h264-deinterlace=true&TranscodeReasons=ContainerNotSupported,%20AudioCodecNotSupported&runtimeTicks=32460000000&actualSegmentLengthTicks=60000000" to "IP Address" in 0:00:00.603524 with Status Code 200
    [2024-02-17 11:22:38.901 +00:00] [INF] Stopping ffmpeg process with q command for "/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8"
    [2024-02-17 11:22:38.939 +00:00] [INF] FFmpeg exited with code 0
    [2024-02-17 11:22:38.941 +00:00] [INF] Deleting partial stream file(s) "/var/lib/jellyfin/transcodes/64ae7322e76997a0b0b6e2f530288e50.m3u8"
    [2024-02-17 11:22:40.498 +00:00] [INF] Playback stopped reported by app "Jellyfin Web" "10.8.13" playing "When You're Lost in the Darkness". Stopped at "3224784" ms
    [2024-02-17 11:22:40.522 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Sessions/Playing/Stopped" to "IP Address" in 0:00:01.6381775 with Status Code 204
    [2024-02-17 11:22:53.590 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Shows/NextUp?limit=1&userId=9518f8219089493195903e064cfeb604" to "IP Address" in 0:00:00.5287214 with Status Code 200
    [2024-02-17 11:22:53.697 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items/Resume?fields=primaryImageAspectRatio&fields=seriesPrimaryImage&fields=seasonUserData&fields=overview&fields=genres&fields=people&fields=chapters&enableUserData=true&limit=20" to "IP Address" in 0:00:00.6357785 with Status Code 200
    [2024-02-17 11:22:54.137 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?recursive=true&enableUserData=true&enableImages=true&limit=20&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&searchTerm=&sortOrder=ascending&sortBy=SortName&includeItemTypes=episode" to "IP Address" in 0:00:00.8682976 with Status Code 200
    [2024-02-17 11:22:54.139 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?recursive=true&enableUserData=true&enableImages=true&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&limit=20&searchTerm=&sortOrder=ascending&sortBy=SortName&includeItemTypes=series" to "IP Address" in 0:00:00.8797829 with Status Code 200
    [2024-02-17 11:22:54.687 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?sortOrder=ascending&searchTerm=&recursive=true&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&sortBy=SortName&includeItemTypes=movie&limit=20&enableUserData=true&enableImages=true" to "IP Address" in 0:00:01.6131367 with Status Code 200
    [2024-02-17 11:22:55.390 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?sortOrder=descending&parentId=1a974e3b219a2c09f2a4748286f80137&enableImages=true&sortBy=DateCreated&sortBy=IsFolder&recursive=true&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&startIndex=0&limit=66&enableUserData=true&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series" to "IP Address" in 0:00:01.164966 with Status Code 200
    [2024-02-17 11:22:55.851 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?enableUserData=true&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&enableImages=true&startIndex=0&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series&parentId=1a974e3b219a2c09f2a4748286f80137&sortBy=DateCreated&sortBy=IsFolder&limit=66&sortOrder=descending&recursive=true" to "IP Address" in 0:00:01.0939481 with Status Code 200
    [2024-02-17 11:22:55.871 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?recursive=true&limit=66&enableImages=true&enableUserData=true&sortBy=DateCreated&sortBy=IsFolder&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series&parentId=a656b907eb3a73532e40e44b968d0225&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&startIndex=0&sortOrder=descending" to "IP Address" in 0:00:01.5742621 with Status Code 200
    [2024-02-17 11:22:56.507 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:22:56.508 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:22:56.512 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=DirectPlay, TranscodeReason=0 ) "mediaConfused-facevideos/659af541-2a81-8b77-6819-5870c5394888/stream.mkv?MediaSourceId=659af5412a818b7768195870c5394888&Static=true&VideoCodec=h264&AudioCodec=truehd&AudioStreamIndex=1&api_key=<token>&SubtitleMethod=Encode&Tag=8cd6bab1027ca2e75be30a1065b784f4"
    [2024-02-17 11:22:56.665 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?enableUserData=true&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series&limit=66&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&recursive=true&parentId=a656b907eb3a73532e40e44b968d0225&sortOrder=descending&enableImages=true&sortBy=DateCreated&sortBy=IsFolder&startIndex=0" to "IP Address" in 0:00:01.1793018 with Status Code 200
    [2024-02-17 11:22:56.691 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?includeItemTypes=movie&includeItemTypes=series&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&sortBy=DateCreated&sortBy=IsFolder&startIndex=0&enableUserData=true&recursive=true&sortOrder=descending&limit=66" to "IP Address" in 0:00:02.9152946 with Status Code 200
    [2024-02-17 11:22:57.097 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?recursive=true&limit=66&enableImages=true&enableUserData=true&sortBy=DateCreated&sortBy=IsFolder&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series&parentId=f137a2dd21bbc1b99aa5c0f6bf02a805&startIndex=0&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&sortOrder=descending" to "IP Address" in 0:00:02.822659 with Status Code 200
    [2024-02-17 11:22:57.263 +00:00] [WRN] Slow HTTP Response from "http://IP Address/Users/9518f8219089493195903e064cfeb604/Items?sortBy=DateCreated&sortBy=IsFolder&enableImages=true&includeItemTypes=movie&includeItemTypes=boxSet&includeItemTypes=series&parentId=f137a2dd21bbc1b99aa5c0f6bf02a805&enableUserData=true&fields=airTime&fields=canDelete&fields=canDownload&fields=channelInfo&fields=chapters&fields=childCount&fields=cumulativeRunTimeTicks&fields=customRating&fields=dateCreated&fields=dateLastMediaAdded&fields=displayPreferencesId&fields=etag&fields=externalUrls&fields=genres&fields=homePageUrl&fields=itemCounts&fields=mediaSourceCount&fields=mediaSources&fields=originalTitle&fields=overview&fields=parentId&fields=path&fields=people&fields=playAccess&fields=productionLocations&fields=providerIds&fields=primaryImageAspectRatio&fields=recursiveItemCount&fields=settings&fields=screenshotImageTags&fields=seriesPrimaryImage&fields=seriesStudio&fields=sortName&fields=specialEpisodeNumbers&fields=studios&fields=basicSyncInfo&fields=syncInfo&fields=taglines&fields=tags&fields=remoteTrailers&fields=mediaStreams&fields=seasonUserData&fields=serviceName&fields=themeSongIds&fields=themeVideoIds&fields=externalEtag&fields=presentationUniqueKey&fields=inheritedParentalRatingValue&fields=externalSeriesId&fields=seriesPresentationUniqueKey&fields=dateLastRefreshed&fields=dateLastSaved&fields=refreshState&fields=channelImage&fields=enableMediaSourceDisplay&fields=width&fields=height&fields=extraIds&fields=localTrailerCount&fields=isHD&fields=specialFeatureCount&sortOrder=descending&recursive=true&startIndex=0&limit=66" to "IP Address" in 0:00:01.8163168 with Status Code 200
    [2024-02-17 11:22:58.184 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:22:58.185 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E02.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=DirectPlay, TranscodeReason=0 ) "mediaConfused-facevideos/822edfaf-bcd3-8c09-eaad-da38c203d0fd/stream.mkv?MediaSourceId=822edfafbcd38c09eaadda38c203d0fd&Static=true&VideoCodec=h264&AudioCodec=truehd&AudioStreamIndex=1&api_key=<token>&SubtitleMethod=Encode&Tag=411213272284bff6d35b9e84ed651b97"
    [2024-02-17 11:23:37.939 +00:00] [INF] Playback stopped reported by app "Jellyfin iOS" "1.0.1" playing "When You're Lost in the Darkness". Stopped at "3220000" ms
    [2024-02-17 11:23:38.027 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:23:38.027 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=DirectPlay, TranscodeReason=0 ) "mediaConfused-facevideos/659af541-2a81-8b77-6819-5870c5394888/stream.mkv?MediaSourceId=659af5412a818b7768195870c5394888&Static=true&VideoCodec=h264&AudioCodec=truehd&AudioStreamIndex=1&api_key=<token>&SubtitleMethod=Encode&Tag=8cd6bab1027ca2e75be30a1065b784f4"
    [2024-02-17 11:23:39.334 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:23:39.335 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E02.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=DirectPlay, TranscodeReason=0 ) "mediaConfused-facevideos/822edfaf-bcd3-8c09-eaad-da38c203d0fd/stream.mkv?MediaSourceId=822edfafbcd38c09eaadda38c203d0fd&Static=true&VideoCodec=h264&AudioCodec=truehd&AudioStreamIndex=1&api_key=<token>&SubtitleMethod=Encode&Tag=411213272284bff6d35b9e84ed651b97"
    [2024-02-17 11:23:45.910 +00:00] [WRN] WS "IP Address" error receiving data: "The remote party closed the WebSocket connection without completing the close handshake."
    [2024-02-17 11:23:45.922 +00:00] [INF] WS "IP Address" closed
    [2024-02-17 11:23:51.096 +00:00] [INF] Playback stopped reported by app "Jellyfin iOS" "1.0.1" playing "When You're Lost in the Darkness". Stopped at "3230000" ms
    [2024-02-17 11:23:51.136 +00:00] [INF] User policy for "Woodsworth". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-02-17 11:23:51.136 +00:00] [INF] StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/media/hdd/Plex/TV Shows/The Last Of Us/S01E01.mp4", AudioStreamIndex=null, SubtitleStreamIndex=null ) => ( PlayMethod=DirectPlay, TranscodeReason=0 ) "mediaConfused-facevideos/659af541-2a81-8b77-6819-5870c5394888/stream.mkv?MediaSourceId=659af5412a818b7768195870c5394888&Static=true&VideoCodec=h264&AudioCodec=truehd&AudioStreamIndex=1&api_key=<token>&SubtitleMethod=Encode&Tag=8cd6bab1027ca2e75be30a1065b784f4"
    [2024-02-17 11:23:55.883 +00:00] [INF] WS "IP Address" request - I have replaced IP information which is why there are random instances of IP ADDRESS and Port
    Hope these logs help Smiling-face
    2024-02-17, 07:16 PM
    On both of your devices, can you set the maximum number of channels to stereo and try again? I see that it is transcoding to 5.1 AAC. It SHOULD work, but I've seen that be problematic for some devices. Perhaps stereo AAC will work fine.
    woodsworth
    2024-02-20, 10:35 AM
    Thanks for the suggestion, I’ll give that a try tonight and will let you know the result.
    Appreciate the help so far.
    woodsworth
    2024-02-21, 05:37 PM
    I’ve been able to try the suggested above, apologies it wasn’t sooner. After switching it to stereo and restarting the app on both, the sound still didn’t play. I have installed the Jellyfin app on my iPad instead of Swiftfin and the audio works in this version, so it’s now just the TV app that isn’t working.
    Not sure what else to try. As a test I also switched max number of channels to 5.1 but no cigar.
    2024-02-21, 06:55 PM
    There are a lot of audio related issues in JF's iOS apps. A lot of users opt to just use Safari.
    woodsworth
    2024-03-09, 08:20 PM
    Thought I’d post an update. I decided to re-rip the Blu-Ray’s including the extra English soundtrack which was AC3 I think and the foreign ones then encoded them with the extra sound tracks. The videos now work with the audio on any of the tracks on the Jellyfin LG TV app so I guess my initial rips and encode had an error or something. Either way, I can now watch it on my telly. Thanks for your help troubleshooting this.
