    Jellyfin Forum Support Troubleshooting Problem with sorting Cyrillic (Russian) titles in content
    mrLumen2
    2024-12-28, 09:30 AM
    Forgive me for my English. After upgrading from version 10.8.13 to version 10.9.11, the sorting order of Cyrillic (Russian) movie (TV series, music) titles was broken. The picture shows that the letter "Я" comes first, and then the letter "А". Alphabetically, the letter "Я" is the last, and content starting with this letter should be at the very end. Updating to version 10.10.3 did not help. Initially, in version 10.8.13, everything was fine. Sorting worked correctly. Is there any way to fix this? (In the settings, "Russian" and "Russia" are set everywhere).
    2024-12-29, 02:55 AM
    If I'm reading this PR correctly, it looks like 10.10 has a fix for this but it isn't enabled by default.
    https://github.com/jellyfin/jellyfin/pull/12378
    I'm asking around about how to enable it. Assuming I'm reading this correctly.
    2024-12-29, 03:34 AM
    How do you have Jellyfin installed and on what operating system?
    mrLumen2
    2024-12-29, 10:44 AM
    Server jellyfin 10.10.3 (Native, exe-install package AMD64) on Windows 10 Pro 1809 64x RU-ru
    2024-12-29, 06:17 PM (This post was last modified: 2024-12-29, 06:18 PM by TheDreadPirate.)
    We are going to add an environment variable in Windows.
    Follow this guide.
    https://www.howtogeek.com/787217/how-to-...-10-or-11/
    Add a new environment variable called "JELLYFIN_TRANSLITERATOR_ID". I'm not sure if the value should be "Cyrillic-Latin" or "Latin-Cyrillic". "Russian-Latin" and vice versa may also work?
    You will need to restart Jellyfin completely (stop jellyfin and close the tray app). Experiment with this and report back how this affects sorting for you.
    mrLumen2
    2024-12-30, 08:35 PM
    (2024-12-29, 06:17 PM)TheDreadPirate Wrote: We are going to add an environment variable in Windows.
    Follow this guide.
    Thks, but its not work. (All was fine in jellyfin 10.8.13 on this OS).
    carawan
    Country:Russia
    2025-06-04, 02:29 PM (This post was last modified: 2025-06-04, 02:33 PM by carawan. Edited 1 time in total.)
    Hi,
    The following entry helped me:
    JELLYFIN_TRANSLITERATOR_ID  Cyrillic-Russian
