    Jellyfin Forum Support Troubleshooting Proxmox LXC Not using Intel ARC 380, only iGPU
    MetricConversion
    2024-07-21, 12:38 AM
    My goals:
    Get Jellyfin to exclusively use the ARC card for transcoding.
    Keep the iGPU available for other containers/VMs.
    Get HDR tone mapping working.
    Learn more about linux along the way.
    Issue:
    Arc Card shows up in Jellyfin container appears to transcode under VA-API using /dev/dri/renderD129 but not HDR
    During documentation and testing I was able to get VA-API transcoding working on renderD129 which was new. HDR tonemapping still crashes.
    QSV does not show the option to use another renderer. HDR tonemapping still crashes.
    I'm at a loss, I've gone over the instructions several times, but I feel like I must be doing something off standard. Any advice and "maybe try this" troubleshooting would be VERY appreciated.
    Proxmox Host machine
    i7-8700 (iGPU UHD 630 enabled)
    z390 with REBAR enabled
    Asrock ARC A380
    Proxmox version 8.2.4
    Jellyfin LXC (config output below)
    First installed using Proxmox Helper Scripts.
    Privilaged container
    Ubuntu 24.04
    Linux 6.8.8-2-pve x86_64
    Jellyfin version 10.9.7
    LXC Configuration:
    #<div align='center'><a href='https%3A//Helper-Scripts.com' target='_blank' rel='noopener noreferrer'><img src='https%3A/>
    #  # Jellyfin LXC
    #  </div>
    arch: amd64
    cores: 6
    features: nesting=1
    hostname: jellyfin
    memory: 6144
    net0: name=eth0,bridge=vmbr0,hwaddr=BC:24:11:A6:C8:6A,ip=dhcp,tag=1,type=veth
    onboot: 1
    ostype: ubuntu
    rootfs: local:101/vm-101-disk-0.raw,size=60G
    swap: 2048
    tags: proxmox-helper-scripts
    lxc.cgroup2.devices.allow: a
    lxc.cap.drop:
    lxc.cgroup2.devices.allow: c 188:* rwm
    lxc.cgroup2.devices.allow: c 189:* rwm
    lxc.mount.entry: /dev/serial/by-id  dev/serial/by-id  none bind,optional,create=dir
    lxc.mount.entry: /dev/ttyUSB0      dev/ttyUSB0      none bind,optional,create=file
    lxc.mount.entry: /dev/ttyUSB1      dev/ttyUSB1      none bind,optional,create=file
    lxc.mount.entry: /dev/ttyACM0      dev/ttyACM0      none bind,optional,create=file
    lxc.mount.entry: /dev/ttyACM1      dev/ttyACM1      none bind,optional,create=file
    lxc.cgroup2.devices.allow: c 226:0 rwm
    lxc.cgroup2.devices.allow: c 226:1 rwm
    lxc.cgroup2.devices.allow: c 226:128 rwm
    lxc.cgroup2.devices.allow: c 226:129 rwm
    lxc.cgroup2.devices.allow: c 29:0 rwm
    lxc.mount.entry: /dev/dri dev/dri none bind,optional,create=dir
    lxc.mount.entry: /dev/fb0 dev/fb0 none bind,optional,create=file
    Host Machine:
    ls -l /dev/dri
    and apt policy intel-opencl-icd  output
    ls -l /dev/dri
    total 0
    drwxr-xr-x 2 root root        120 Jul 17 09:25 by-path
    crw-rw---- 1 root video  226,  0 Jul 17 09:25 card0
    crw-rw---- 1 root video  226,  1 Jul 17 09:25 card1
    crw-rw---- 1 root render 226, 128 Jul 17 09:25 renderD128
    crw-rw---- 1 root render 226, 129 Jul 17 09:25 renderD129
    intel-opencl-icd:
      Installed: 22.43.24595.41-1
      Candidate: 22.43.24595.41-1
      Version table:
    *** 22.43.24595.41-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            100 /var/lib/dpkg/status
    Jellyfin LXC:
    ls -l /dev/dri
    ls -l /dev/dri
    total 0
    intel-opencl-icd:
      Installed: 23.43.27642.40-1ubuntu3
      Candidate: 23.43.27642.40-1ubuntu3
      Version table:
    *** 23.43.27642.40-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    Jellyfin LXC groups and lshw -C Display output:
    groups jellyfin
    jellyfin : jellyfin video render input ssl-cert
    lshw -C display
      *-display
          description: VGA compatible controller
          product: DG2 [Arc A380]
          vendor: Intel Corporation
          physical id: 0
          bus info: pci@0000:03:00.0
          version: 05
          width: 64 bits
          clock: 33MHz
          capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
          configuration: driver=i915 latency=0
          resources: iomemory:400-3ff irq:138 memory:50000000-50ffffff memory:4000000000-400fffffff memory:51000000-511fffff
      *-display
          product: CoffeeLake-S GT2 [UHD Graphics 630]
          physical id: 2
          bus info: pci@0000:00:02.0
          version: 00
          width: 64 bits
          clock: 33MHz
          resources: iomemory:400-3ff irq:137 memory:4011000000-4011ffffff memory:40000000-4fffffff ioport:3000(size=64) memory:c0000-dffff
    renderD128 (iGPU UHD 630):
    /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    and /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=vaConfused-facedev/dri/renderD128 -init_hw_device
    Trying display: drm
    libva info: VA-API version 1.21.0
    libva info: Found init function __vaDriverInit_1_21
    vainfo: VA-API version: 1.21 (libva 2.21.0)
    vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 24.2.3 (7c1c775)
          VAProfileMPEG2Simple            : VAEntrypointEncSlice
          VAProfileMPEG2Main              : VAEntrypointEncSlice
          VAProfileH264Main              : VAEntrypointFEI
          VAProfileH264High              : VAEntrypointFEI
          VAProfileH264ConstrainedBaseline: VAEntrypointFEI
          VAProfileVP8Version0_3          : VAEntrypointVLD
          VAProfileVP8Version0_3          : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointFEI
          VAProfileHEVCMain10            : VAEntrypointEncSlice
    /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=va:/dev/dri/renderD128 -init_hw_device
    opencl@va
    [AVHWDeviceContext @ 0x5c005bfd8800] libva: VA-API version 1.21.0
    [AVHWDeviceContext @ 0x5c005bfd8800] libva: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/iHD_drv_video.so
    [AVHWDeviceContext @ 0x5c005bfd8800] libva: Found init function __vaDriverInit_1_21
    [AVHWDeviceContext @ 0x5c005bfd8800] libva: va_openDriver() returns 0
    [AVHWDeviceContext @ 0x5c005bfd8800] Initialised VAAPI connection: version 1.21
    [AVHWDeviceContext @ 0x5c005bfd8800] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 24.2.3 (7c1c775).
    [AVHWDeviceContext @ 0x5c005bfd8800] Driver not found in known nonstandard list, using standard behaviour.
    [AVHWDeviceContext @ 0x5c005bffe400] 0.0: Intel(R) OpenCL Graphics / Intel(R) UHD Graphics 630
    [AVHWDeviceContext @ 0x5c005bffe400] Intel QSV to OpenCL mapping function found (clCreateFromVA_APIMediaSurfaceINTEL).
    [AVHWDeviceContext @ 0x5c005bffe400] Intel QSV in OpenCL acquire function found (clEnqueueAcquireVA_APIMediaSurfacesINTEL).
    [AVHWDeviceContext @ 0x5c005bffe400] Intel QSV in OpenCL release function found (clEnqueueReleaseVA_APIMediaSurfacesINTEL).
    renderD129 (ARC A380):
    /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD129
    AND /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=vaConfused-facedev/dri/renderD129 -init_hw_device
    Trying display: drm
          VAProfileHEVCMain              : VAEntrypointEncSliceLP
          VAProfileHEVCMain10            : VAEntrypointEncSliceLP
          VAProfileVP9Profile0            : VAEntrypointEncSliceLP
          VAProfileVP9Profile1            : VAEntrypointVLD
          VAProfileVP9Profile1            : VAEntrypointEncSliceLP
          VAProfileVP9Profile2            : VAEntrypointEncSliceLP
          VAProfileVP9Profile3            : VAEntrypointVLD
          VAProfileVP9Profile3            : VAEntrypointEncSliceLP
          VAProfileHEVCMain12            : VAEntrypointVLD
          VAProfileHEVCMain422_10        : VAEntrypointVLD
          VAProfileHEVCMain422_10        : VAEntrypointEncSliceLP
          VAProfileHEVCMain422_12        : VAEntrypointVLD
          VAProfileHEVCMain444            : VAEntrypointVLD
          VAProfileHEVCMain444            : VAEntrypointEncSliceLP
          VAProfileHEVCMain444_10        : VAEntrypointVLD
          VAProfileHEVCMain444_10        : VAEntrypointEncSliceLP
          VAProfileHEVCMain444_12        : VAEntrypointVLD
          VAProfileHEVCSccMain            : VAEntrypointVLD
          VAProfileHEVCSccMain            : VAEntrypointEncSliceLP
          VAProfileHEVCSccMain10          : VAEntrypointVLD
          VAProfileHEVCSccMain10          : VAEntrypointEncSliceLP
          VAProfileHEVCSccMain444        : VAEntrypointVLD
          VAProfileHEVCSccMain444        : VAEntrypointEncSliceLP
          VAProfileAV1Profile0            : VAEntrypointVLD
          VAProfileAV1Profile0            : VAEntrypointEncSliceLP
          VAProfileHEVCSccMain444_10      : VAEntrypointVLD
          VAProfileHEVCSccMain444_10      : VAEntrypointEncSliceLP
    /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=va:/dev/dri/renderD129 -init_hw_device
    opencl@va
    [AVHWDeviceContext @ 0x5c6beac23800] libva: VA-API version 1.21.0
    [AVHWDeviceContext @ 0x5c6beac23800] libva: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/iHD_drv_video.so
    [AVHWDeviceContext @ 0x5c6beac23800] libva: Found init function __vaDriverInit_1_21
    [AVHWDeviceContext @ 0x5c6beac23800] libva: va_openDriver() returns 0
    [AVHWDeviceContext @ 0x5c6beac23800] Initialised VAAPI connection: version 1.21
    [AVHWDeviceContext @ 0x5c6beac23800] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 24.2.3 (7c1c775).
    [AVHWDeviceContext @ 0x5c6beac23800] Driver not found in known nonstandard list, using standard behaviour.
    [AVHWDeviceContext @ 0x5c6beac52100] No matching devices found.
    Device creation failed: -19.
    Failed to set value 'opencl@va' for option 'init_hw_device': No such device
    Error parsing global options: No such device
    ffmpeg log for 4k HDR film transcode attempt using VA-API and renderD129:
    {"Protocol":0,"Id":"659cbc701cd9a23626b87bbcc5b5e049","Path":"/PATHTOFILM/FILM 2160P x265 HVEC 10BIT HDR.MKV","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"mkv","Size":16670486639,"Name":"FILM 2160P x265 HVEC 10BIT HDR","IsRemote":false,"ETag":"5901e2ac0151a7d43961347b7195d386","RunTimeTicks":77101000000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"hevc","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":"bt2020nc","ColorTransfer":"smpte2084","ColorPrimaries":"bt2020","DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":2,"VideoRangeType":2,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"4K HEVC HDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":17297297,"BitDepth":10,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":2160,"Width":3840,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":1,"AspectRatio":"16:9","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p10le","Level":150,"IsAnamorphic":false},{"Codec":"aac","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"English - AAC - 5.1 - Default","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"5.1","BitRate":697108,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":"LC","Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"eng","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"English - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"ara","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Arabic - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"chi","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Chi - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":4,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"cze","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Cze - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":5,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"dan","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Danish - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":6,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"dut","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Dut - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":7,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"fin","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Finnish - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":8,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"fre","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Fre - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":9,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"ger","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Ger - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":10,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"ger","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":"Forced","VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Forced - Ger - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":11,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"hun","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Hungarian - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":12,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"kor","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Korean - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":13,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"nob","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Norwegian Bokm\u00E5l - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":14,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"pol","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Polish - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":15,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"rum","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Rum - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":16,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"spa","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Spanish - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":17,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"swe","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Swedish - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":18,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"DVDSUB","CodecTag":null,"Language":"tha","ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Thai - DVDSUB","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":19,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":17994405,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -ss 00:00:09.000 -noaccurate_seek -init_hw_device opencl=ocl:0.0 -filter_hw_device ocl -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i file:"/PATHTOFILM/FILM 2160P x265 HVEC 10BIT HDR.MKV" -noautoscale -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_vaapi -rc_mode VBR -b:v 28828828 -maxrate 28828828 -bufsize 57657656 -sei -a53_cc -force_key_frames:0 "expr:gte(t,n_forced*3)" -vf "setparams=color_primaries=bt2020:color_trc=smpte2084:colorspace=bt2020nc,hwdownload,format=p010le,hwupload=derive_device=opencl,tonemap_opencl=format=nv12:p=bt709:t=bt709:m=bt709:tonemap=bt2390:peak=100:desat=0,hwdownload,format=nv12,hwupload_vaapi" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -ar 48000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "bcd39ba2d2d95a48a37de4669c1513a0-1.mp4" -start_number 3 -hls_segment_filename "/var/lib/jellyfin/transcodes/bcd39ba2d2d95a48a37de4669c1513a0%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/var/lib/jellyfin/transcodes/bcd39ba2d2d95a48a37de4669c1513a0.m3u8"
    [AVHWDeviceContext @ 0x5ca7d801a7c0] QSV to OpenCL mapping not usable.
    Input #0, matroska,webm, from 'file:/PATHTOFILM/FILM 2160P x265 HVEC 10BIT HDR.MKV':
      Metadata:
        title          : FILM NAME
        encoder        : libebml v1.3.9 + libmatroska v1.5.2
        creation_time  : 2020-10-04T00:05:13.000000Z
      Duration: 02:08:30.10, start: 0.000000, bitrate: 17297 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 411.160750
          Metadata:
            title          : Chapter 01
        Chapter #0:1: start 411.160750, end 694.819125
          Metadata:
            title          : Chapter 02
        Chapter #0:2: start 694.819125, end 946.278667
          Metadata:
            title          : Chapter 03
        Chapter #0:3: start 946.278667, end 1153.485667
          Metadata:
            title          : Chapter 04
        Chapter #0:4: start 1153.485667, end 1413.453708
          Metadata:
            title          : Chapter 05
        Chapter #0:5: start 1413.453708, end 1674.464458
          Metadata:
            title          : Chapter 06
        Chapter #0:6: start 1674.464458, end 1925.840583
          Metadata:
            title          : Chapter 07
        Chapter #0:7: start 1925.840583, end 2232.939042
          Metadata:
            title          : Chapter 08
        Chapter #0:8: start 2232.939042, end 2454.910792
          Metadata:
            title          : Chapter 09
        Chapter #0:9: start 2454.910792, end 2681.804125
          Metadata:
            title          : Chapter 10
        Chapter #0:10: start 2681.804125, end 2864.278083
          Metadata:
            title          : Chapter 11
        Chapter #0:11: start 2864.278083, end 3056.553500
          Metadata:
            title          : Chapter 12
        Chapter #0:12: start 3056.553500, end 3322.193875
          Metadata:
            title          : Chapter 13
        Chapter #0:13: start 3322.193875, end 3549.045500
          Metadata:
            title          : Chapter 14
        Chapter #0:14: start 3549.045500, end 3789.160375
          Metadata:
            title          : Chapter 15
        Chapter #0:15: start 3789.160375, end 3972.635333
          Metadata:
            title          : Chapter 16
        Chapter #0:16: start 3972.635333, end 4278.565958
          Metadata:
            title          : Chapter 17
        Chapter #0:17: start 4278.565958, end 4483.896083
          Metadata:
            title          : Chapter 18
        Chapter #0:18: start 4483.896083, end 4660.906250
          Metadata:
            title          : Chapter 19
        Chapter #0:19: start 4660.906250, end 5019.681333
          Metadata:
            title          : Chapter 20
        Chapter #0:20: start 5019.681333, end 5171.541375
          Metadata:
            title          : Chapter 21
        Chapter #0:21: start 5171.541375, end 5461.414292
          Metadata:
            title          : Chapter 22
        Chapter #0:22: start 5461.414292, end 5719.964250
          Metadata:
            title          : Chapter 23
        Chapter #0:23: start 5719.964250, end 5990.567917
          Metadata:
            title          : Chapter 24
        Chapter #0:24: start 5990.567917, end 6265.259000
          Metadata:
            title          : Chapter 25
        Chapter #0:25: start 6265.259000, end 6506.541708
          Metadata:
            title          : Chapter 26
        Chapter #0:26: start 6506.541708, end 6847.298792
          Metadata:
            title          : Chapter 27
        Chapter #0:27: start 6847.298792, end 6972.090125
          Metadata:
            title          : Chapter 28
        Chapter #0:28: start 6972.090125, end 7230.765208
          Metadata:
            title          : Chapter 29
        Chapter #0:29: start 7230.765208, end 7710.077375
          Metadata:
            title          : Chapter 30
      Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn (default)
        Metadata:
          BPS-eng        : 16510554
          DURATION-eng    : 02:08:30.078000000
          NUMBER_OF_FRAMES-eng: 184857
          NUMBER_OF_BYTES-eng: 15912207872
          _STATISTICS_WRITING_APP-eng: mkvmerge v38.0.0 ('The Silent Type') 64-bit
          _STATISTICS_WRITING_DATE_UTC-eng: 2020-10-04 00:05:13
          _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      Stream #0:1(eng): Audio: aac (LC), 48000 Hz, 5.1, fltp (default)
        Metadata:
          BPS-eng        : 697108
          DURATION-eng    : 02:08:30.080000000
          NUMBER_OF_FRAMES-eng: 361410
          NUMBER_OF_BYTES-eng: 671845060
      Stream #0:2(eng): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 10661
          DURATION-eng    : 02:00:09.032000000
          NUMBER_OF_FRAMES-eng: 1508
          NUMBER_OF_BYTES-eng: 9607724
      Stream #0:3(ara): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 5194
          DURATION-eng    : 02:06:44.127000000
          NUMBER_OF_FRAMES-eng: 1442
          NUMBER_OF_BYTES-eng: 4937646
      Stream #0:4(chi): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 7476
          DURATION-eng    : 02:06:37.162000000
          NUMBER_OF_FRAMES-eng: 1446
          NUMBER_OF_BYTES-eng: 7100436
      Stream #0:5(cze): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 8061
          NUMBER_OF_FRAMES-eng: 1417
          NUMBER_OF_BYTES-eng: 7662458
      Stream #0:6(dan): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 8589
          DURATION-eng    : 02:06:44.169000000
          NUMBER_OF_FRAMES-eng: 1296
          NUMBER_OF_BYTES-eng: 8164850
      Stream #0:7(dut): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 8238
          DURATION-eng    : 01:59:19.770000000
          NUMBER_OF_FRAMES-eng: 1116
          NUMBER_OF_BYTES-eng: 7373224
      Stream #0:8(fin): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 9130
          NUMBER_OF_FRAMES-eng: 1332
          NUMBER_OF_BYTES-eng: 8678547
      Stream #0:9(fre): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 7510
          DURATION-eng    : 02:06:43.919000000
          NUMBER_OF_FRAMES-eng: 1490
          NUMBER_OF_BYTES-eng: 7138840
      Stream #0:10(ger): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 12677
          DURATION-eng    : 02:00:09.111000000
          NUMBER_OF_FRAMES-eng: 1562
          NUMBER_OF_BYTES-eng: 11424588
      Stream #0:11(ger): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          title          : Forced
          BPS-eng        : 188
          DURATION-eng    : 00:56:13.405000000
          NUMBER_OF_FRAMES-eng: 19
          NUMBER_OF_BYTES-eng: 79516
      Stream #0:12(hun): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 7753
          NUMBER_OF_FRAMES-eng: 1344
          NUMBER_OF_BYTES-eng: 7369780
      Stream #0:13(kor): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 5864
          NUMBER_OF_FRAMES-eng: 1405
          NUMBER_OF_BYTES-eng: 5568744
      Stream #0:14(nob): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 9117
          DURATION-eng    : 01:59:21.359000000
          NUMBER_OF_FRAMES-eng: 1427
          NUMBER_OF_BYTES-eng: 8161703
      Stream #0:15(pol): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 8295
          DURATION-eng    : 01:58:52.873000000
          NUMBER_OF_FRAMES-eng: 1083
          NUMBER_OF_BYTES-eng: 7396528
      Stream #0:16(rum): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 9509
          NUMBER_OF_FRAMES-eng: 1450
          NUMBER_OF_BYTES-eng: 9038766
      Stream #0:17(spa): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 9596
          DURATION-eng    : 01:59:20.400000000
          NUMBER_OF_FRAMES-eng: 1422
          NUMBER_OF_BYTES-eng: 8589409
      Stream #0:18(swe): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 9854
          DURATION-eng    : 01:59:19.766000000
          NUMBER_OF_FRAMES-eng: 1381
          NUMBER_OF_BYTES-eng: 8819129
      Stream #0:19(tha): Subtitle: dvd_subtitle, 1920x1080
        Metadata:
          BPS-eng        : 8480
          NUMBER_OF_FRAMES-eng: 1437
          NUMBER_OF_BYTES-eng: 8060610
    Stream mapping:
      Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_vaapi))
      Stream #0:1 -> #0:1 (aac (native) -> aac (libfdk_aac))
    [hls @ 0x5ca7d9021fc0] Opening '/var/lib/jellyfin/transcodes/bcd39ba2d2d95a48a37de4669c1513a0-1.mp4' for writing
    Output #0, hls, to '/var/lib/jellyfin/transcodes/bcd39ba2d2d95a48a37de4669c1513a0.m3u8':
      Metadata:
        encoder        : Lavf60.3.100
      Stream #0:0: Video: h264 (High), vaapi(tv, bt709, progressive), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 28828 kb/s, 23.98 fps, 24k tbn (default)
        Metadata:
          encoder        : Lavc60.3.100 h264_vaapi
      Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 256 kb/s (default)
        Metadata:
          encoder        : Lavc60.3.100 libfdk_aac
    frame=    0 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A speed=  0x
    frame=    2 fps=0.0 q=-0.0 size=N/A time=00:00:00.34 bitrate=N/A speed=0.593x
    [q] command received. Exiting.
    [hls @ 0x5ca7d9021fc0] Opening '/var/lib/jellyfin/transcodes/bcd39ba2d2d95a48a37de4669c1513a03.mp4' for writing
    frame=  15 fps= 13 q=-0.0 Lsize=N/A time=00:00:00.72 bitrate=N/A speed=0.649x
    video:587kB audio:33kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
    2024-07-21, 01:14 AM (This post was last modified: 2024-07-21, 01:15 AM by TheDreadPirate.)
    The Intel driver will use the first Intel device available, which is usually the iGPU. Your choices are to disable the iGPU in your BIOS or pass in only the Arc GPU into the LXC. Probably /dev/dri/renderD129.
    MetricConversion
    2024-07-21, 06:37 AM (This post was last modified: 2024-07-21, 06:39 AM by MetricConversion. Edited 1 time in total.)
    I appreciate the help.
    I tried mapping JUST the renderD129, and the by-path directories for the correct cards, but that just flat out wouldn't use either VA-API or QSV.
    I will give turning off the iGPU at the bios a shot just to test if that is even a solution.
    This might be a whole lot easier if I just moved to a full-fat VM where I could very clearly control the PCI pass through. I have just gathered moving a Jellyfin instance is not a simple task.
    2024-07-21, 02:37 PM (This post was last modified: 2024-07-21, 02:38 PM by TheDreadPirate.)
    I opted to disable my iGPU entirely.
    Moving Jellyfin is simple as long as the install types are the same. As in docker to docker or package install to package install.
    MetricConversion
    2024-07-23, 12:57 AM
    Thanks again for your replies and insight.
    Ok with iGPU set to auto in bios, confirmed its off in Host /dev/dri only showing the RenderD128 which identifies via lspci as the A380.
    No dialogs pop up on failure, only hangs.
    QSV hangs on everything.
    VA-API works, but is slower to start up than iGPU with QSV. This is usable, but obviously worse than iGPU. HDR content still hangs!
    I know there are linux kernel issues with HDR conversion, but I'm unclear on how to resolve that. Does it need to be a newer linux kernel in the host or the lxc or both?
    How can I diagnose why QSV isn't working?
    MetricConversion
    2024-07-23, 01:09 AM (This post was last modified: 2024-07-23, 01:26 AM by MetricConversion. Edited 2 times in total.)
    Ok realized there were some updates for the host, the container, and jellyfin. I'll do some more testing and come back. Initially it looks like QSV might be working?
    EDIT: Absolutely not working. I had played a native h264 file by mistake. h265 files, QSV not working and now VA-API is no longer working. This is extremely demoralizing.
    EDIT 2: I unchecked Hardware acceleration and now its working? And it shows up as activity on intel_gpu_top? I genuinely don't understand this.
    2024-07-23, 01:30 AM
    What kernel are you currently running? There are some kernel i915 driver bugs in 6.8 and 6.9.
    MetricConversion
    2024-07-23, 03:09 AM
    Oh interesting learned something today.
    The Host (and the LXC) both are running:
    Linux 6.8.8-3-pve x86_64
    I'm assuming thats how the LXCs work, they piggyback off the host's kernel?
    MetricConversion
    2024-07-23, 03:15 AM
    I'm having a look at what it'd take to pass the GPU into VM instead of a container and I see why you went with a dedicated machine for this.
    2024-07-23, 01:13 PM (This post was last modified: 2024-07-23, 02:21 PM by TheDreadPirate. Edited 2 times in total.)
    Yeah. I believe 6.8.8 still has the kernel driver bug in it.
    AFAICT, Proxmox doesn't do backporting of patches like Ubuntu and Red Hat. So your options are to roll back to 6.8.4, the release prior to the commits that broke Arc transcoding, or YOLO and update to 6.9.4+, which incorporates both patches that fix Intel Arc transcoding.
    Or, like you're thinking, use a VM.
