    Jellyfin Forum Support General Questions Recommended HDR -> SDR tone mapping settings?
    Trying to get a better understanding of how tone mapping works.
    LeviSnoot
    Country:Sweden
    2023-09-17, 01:04 PM
    I'm never quite sure which tone mapping parameters will do the best job at accurately convering HDR content to SDR. So I thought I'd ask here. This is especially because, lately I've been working with HDR files in Photoshop and Premiere, and it stunned me a bit how little effort it takes to tone map well there. All you really have to do is make sure the correct color profile is applied to the document/sequence and from there, it's all done automatically. It also looks great, like I'd expect native SDR content to look.
    Right now I'm using the VPP Tone Mapping in Jellyfin, at default settings (Brightness Gain: 16, Contrast Gain: 1), and I get acceptable results for the most part. Sometimes I do feel like the video is a bit darker than it should be, and perhaps a bit too contrasty as well.
    Before I migrated to a dedicated server for JF, I used the native tone mapping settings, and had okay results with the following parameters:
    Algorithm: Mobius
    Mode: Auto
    Range: Auto
    Desat: 0.5
    Peak: 100
    Param: 0.3
    I also applied similar settings in JF Media Player's mpv.conf file, again with decent results:
    # HDR Tone Mapping
    tone-mapping='mobius'
    tone-mapping-max-boost='3.5'
    tone-mapping-param='0.3'
    gamut-mapping-mode='perceptual'
    hdr-compute-peak='yes'
    I do feel like these settings can be improved though, especially after seeing the results I get in Adobe apps. Any recommendations?
    JF Server Specs:
    • CPU: Intel Core i5-11400
    • Motherboard: ASRock H510M-ITX/ac
    • RAM: G.Skill 16GB (2x8GB) Value 2666MHz CL19 DDR4
    • PSU: Silverstone SX300-B 80+ Bronze SFX
    • OS: Debian 12
    • JF: 10.10.1
    LeviSnoot
    Country:Sweden
    2023-09-17, 01:35 PM
    For the sake of completeness I'll attach a sample below. Doing this was a good idea because the results of the tone mapping settings I have are a lot worse than I initially thought... Yikes.
    Adobe:
    [Image: IDwawjY.jpeg]
    Jellyfin Native Tone Mapping:
    [Image: pVmDbLu.jpeg]
    MPV/Jellyfin Media Player:
    [Image: XAJuwGV.jpeg]
    Jellyfin VPP Tone Mapping:
    [Image: nTElTBe.jpeg]
    I think what I'd like is somewhere between the first and second image. Adobe has a good image in general, but is maybe slightly oversaturated/bright (there's a lot of color noise in the grain for example), and it looks like the highlights are clipping a bit. The native tone mapping settings look pretty nice to me, although I feel they're still a bit flat.
    JF Server Specs:
    • OS: Debian 12
    • JF: 10.10.1
    grabbend
    2023-11-27, 11:24 AM
    Do you have any updates @LeviSnoot?
    LeviSnoot
    Country:Sweden
    2023-11-29, 10:13 PM
    (2023-11-27, 11:24 AM)grabbend Wrote: Do you have any updates @LeviSnoot?
    Unfortunately no, hopefully someone will provide some good examples to try here eventually. Until then, I feel a bit out of my depth.
    JF Server Specs:
    • OS: Debian 12
    • JF: 10.10.1
