    Jellyfin Forum Support Troubleshooting Media Scanning & Identification Scan stuck with same media
    sirlordcomic
    2023-12-31, 02:01 PM (This post was last modified: 2023-12-31, 02:09 PM by sirlordcomic. Edited 2 times in total.)
    Hi everyone,
    I started using Jellyfin about 6 months ago on my Synology NAS, and suddenly facing a strange issue where the same media will not import.
    I started having issues with MKV files so I installed new version using Docker, but I have also tried the Synology app version.
    I have a mix of film, tv, and home videos. I've tried to narrow down the issue to the film folder, it gets stuck at 74%
    How can I enable a debug log to share?
    This is what I have after clicking Scan:
    [2023-12-31 14:02:33.644 +00:00] [INF] [49] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing "Scan Media Library"
    [2023-12-31 14:02:33.654 +00:00] [INF] [49] Emby.Server.Implementations.Library.LibraryManager: Validating media library
    [2023-12-31 14:03:06.742 +00:00] [INF] [22] Jellyfin.Api.Auth.CustomAuthenticationHandler: "CustomAuthentication" was not authenticated. Failure message: "Invalid token."
    [2023-12-31 14:03:06.742 +00:00] [INF] [22] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: "CustomAuthentication" was challenged.
    [2023-12-31 14:03:06.751 +00:00] [INF] [49] Jellyfin.Api.Auth.CustomAuthenticationHandler: "CustomAuthentication" was not authenticated. Failure message: "Invalid token."
    [2023-12-31 14:03:06.751 +00:00] [INF] [49] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: "CustomAuthentication" was challenged.
    [2023-12-31 14:04:06.657 +00:00] [INF] [49] Jellyfin.Api.Auth.CustomAuthenticationHandler: "CustomAuthentication" was not authenticated. Failure message: "Invalid token."
    [2023-12-31 14:04:06.658 +00:00] [INF] [49] Jellyfin.Api.Auth.CustomAuthenticationHandler: "CustomAuthentication" was not authenticated. Failure message: "Invalid token."
    [2023-12-31 14:04:06.658 +00:00] [INF] [49] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: "CustomAuthentication" was challenged.
    [2023-12-31 14:04:06.666 +00:00] [INF] [51] Jellyfin.Api.Auth.CustomAuthenticationHandler: "CustomAuthentication" was not authenticated. Failure message: "Invalid token."
    [2023-12-31 14:04:06.667 +00:00] [INF] [51] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: "CustomAuthentication" was challenged.
    thanks
    *maybe related to this?
    https://forum.jellyfin.org/t-solved-migr...-libraries
    Venson
    Threads: 8
    2023-12-31, 02:30 PM
    You said suddenly it does not "import" anymore?
    Did you recently upgrade to 10.8.13?
    Jellyfin 10.11.0 release will be Soon™
    [Image: default-yellow.png]
