    Jellyfin Forum Support Troubleshooting SOLVED: Jellyfin does not trancscode 4K HEVC in web player
    bioblatt
    2024-07-24, 06:55 PM
    still the same issue
    2024-07-24, 06:58 PM
    I'm sorry if you've answered this. There are like 3 threads with similar issues.
    What browser are you using and what version?
    bioblatt
    2024-07-24, 07:05 PM
    No problem Smiling-face I'm really thankful for your great support.
    I'm using Firefox 128.0 (64-Bit) on Windows 10 but it's also not working on my Android phone (Android 13) Jellyfin version 2.6.2 with the default Web player. The integrated player works fine.
    2024-07-24, 08:07 PM
    Are you using a reverse proxy?
    bioblatt
    2024-07-24, 08:18 PM (This post was last modified: 2024-07-24, 08:21 PM by bioblatt. Edited 1 time in total.)
    Yes, I use Nginx as a reverse proxy.
    Here's my config:
    server {
          server_name my_domain;
          access_log /var/log/nginx/jellyfin.access;
          error_log /var/log/nginx/jellyfin.error;
          set $jellyfin 127.0.0.1;
          location / {
              proxy_pass http://127.0.0.1:8096;
              proxy_set_header Host $host;
              proxy_set_header X-Real-IP $remote_addr;
              proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
              proxy_set_header X-Forwarded-Proto $scheme;
              proxy_set_header X-Forwarded-Protocol $scheme;
              proxy_set_header X-Forwarded-Host $http_host;
              # Disable buffering when the nginx proxy gets very resource heavy upon streaming
              proxy_buffering off;
          location /socket {
              # Proxy Jellyfin Websockets traffic
              proxy_pass http://$127.0.0.1:8096;
              proxy_http_version 1.1;
              proxy_set_header Upgrade $http_upgrade;
              proxy_set_header Connection "upgrade";
            # Security / XSS Mitigation Headers
            #add_header X-Frame-Options "SAMEORIGIN";
            add_header Cross-Origin-Resource-Policy "cross-origin" always;
            add_header X-XSS-Protection "1; mode=block";
            add_header X-Content-Type-Options "nosniff";
        listen 443 ssl; # managed by Certbot
        ssl_certificate /etc/letsencrypt/live/my_domain/fullchain.pem; # managed by Certbot
        ssl_certificate_key /etc/letsencrypt/live/my_domain/privkey.pem; # managed by Certbot
        include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
        ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
    server {
        if ($host = my_domain) {
            return 301 https://$host$request_uri;
        } # managed by Certbot
          listen 80;
        return 404; # managed by Certbot
    2024-07-24, 09:03 PM
    For testing, can you set X-XSS-Protection from "1; mode=block" to "0". Our documentation says to not enable it, period.
        # NOTE: X-Frame-Options may cause issues with the webOS app
        add_header X-XSS-Protection "0"; # Do NOT enable. This is obsolete/dangerous
    Reload nginx and try again.
    bioblatt
    2024-07-24, 09:13 PM
    Done. Made no difference.
    bioblatt
    2024-07-27, 11:48 PM
    Anything else I can try?
    2024-07-28, 12:27 AM
    You've got me stumped. Are you using any extensions in the browser?
    bioblatt
    2024-07-28, 07:45 AM
    Yes but like I said, this also happens on the android app.
