    Jellyfin Forum Support Troubleshooting SOLVED: Onn 4k Pro freezing/stuttering (not buffering)
    SilveryAbaba
    2025-08-26, 06:57 PM
    After running flawlessly for a long time Onn started freezing during playback.
    It isn't buffering because the connection is great, I set up a laptop there and it plays the same media via wifi perfectly. I figured it was an internet problem anyway and finally got around to running ethernet to it, but it made no difference.
    I did a factory reset and installed just tailscale (to access the server) and jellyfin, and it's still continuing.
    I tried disabling game mode, frame match, bluetooth, etc.
    I tried an kodi as an external player but it suffers the same behavior.
    I set up kodi jellyfin add on and it also suffers.
    I had to disable nvidia because the container stopped launching with it, but the issue came awhile after that. Regardless, the media is direct play.
    I put the media on a thumbdrive and it played it just fine.
    docker-compose:
        image: jellyfin/jellyfin
        container_name: jellyfin
        networks:
          - bridge_network
          - backend_network
        user: 1000:1000
          - jellyconfigconfig
          - jellycachecache
          - /media/8tb/moviesConfused-faceMovies
        restart: unless-stopped
        #runtime: nvidia
        #deploy:
        #  resources:
        #    reservations:
        #      devices:
        #        - driver: nvidia
        #          count: all
        #          capabilities: [gpu]
    any ideas?
    SykesSharkTale
    2025-09-01, 03:27 AM
    Hi, I'm having the same issue with the Onn 4k Pro. When the video starts playing it instantly starts stuttering and looks like a lower framerate.
    For me it's occuring on HEVC encoded videos using direct play. Anything h264 seems ok, regardless of resolution.
    Network connectivity is also not the problem. I can use VLC to play HEVC videos just fine with no transcoding.
    Tried multiple cables, changing resolution and color profiles and I couldn't find a solution.
    SykesSharkTale
    2025-09-01, 03:36 AM
    Just found this thread on the Jellyfin Android TV GitHub: https://github.com/jellyfin/jellyfin-and...ssues/3233
    It's possibly an issue that goes deeper than the Jellyfin app
    SilveryAbaba
    2025-10-12, 08:43 PM
    (2025-09-01, 03:27 AM)SykesSharkTale Wrote: Hi, I'm having the same issue with the Onn 4k Pro. When the video starts playing it instantly starts stuttering and looks like a lower framerate.
    Okay I finally figured out what it was for me. It was actually some stupid LG TV setting (why can't they just be monitors anymore, ugh!). I followed this video: https://www.youtube.com/watch?v=p7BBkRI29X4
    I think it was the Display -> Clarity -> TruMotion De-Judder and De-Blur both set to 2 at 18:22 that fixed it?
