    Jellyfin Forum Support Troubleshooting SOLVED: Playlist disappear right after library scan
    Pages (3): 1 2 3 Next »
    Jolaru21
    Threads: 27
    Country:Spain
    2024-09-25, 01:48 PM
    As title says, Playlist disappear right after library scan, and I found the folder "playlists" on jf path and still there, but not on my media anymore.
    Someone knows how to fix this?
    I want to add a playlist for recommended halloween movies for every user on my server.
    Thanks!
    2024-09-25, 02:34 PM
    Can you share your logs via pastebin?
    Jolaru21
    Threads: 27
    Country:Spain
    2024-09-25, 04:27 PM
    I would like to, but there is no log about this Confused-face.
    It just happens every time after scan library. It removes the playlist created.
    2024-09-25, 08:47 PM
    Try this: Go to Dashboard → Scheduled Tasks → Maintenance → Clean up collections and playlists, and delete "On application startup." This will help if your mounts aren’t detected immediately at startup.
    pixel24
    Threads: 56
    2024-09-25, 08:54 PM
    Yes, I had the same problem. All my media is stored on an SMB/ADS server. With version 10.9, my playlists kept getting completely wiped out. Even after disabling Jellyfin from starting automatically and manually checking before the Jellyfin start that the mount was correctly bound and all libraries were available, the issue persisted.
    In the end, I removed the script responsible for this. Well, what can I say? At least it works now.
    Jolaru21
    Threads: 27
    Country:Spain
    2024-09-25, 10:49 PM (This post was last modified: 2024-09-25, 10:52 PM by Jolaru21.)
    (2024-09-25, 08:47 PM)theguymadmax Wrote: Try this: Go to Dashboard → Scheduled Tasks → Maintenance → Clean up collections and playlists, and delete "On application startup." This will help if your mounts aren’t detected immediately at startup.
    That's not the solution for this problem, because it wasn't executed since 4 days, so it can't be, but thanks anyway
    Pixel24, what do you mean? In my case, I didn't reboot the server, I just reescan the library and right after, it disappear, which script did you deleted?
    pixel24
    Threads: 56
    2024-09-26, 10:22 AM
    Ok, that was a misunderstanding. In my case, all playlists were emptied when the server started, even though all mounts were available. I then removed the script mentioned above.
    I don't recall the problem occurring during the media scan. Sorry for the confusion.
    I was able to observe the process "Removing items from playlists" in the logfile while manually starting the Jellyfin server. Have you checked the logfile during the media scan to see if it gives any clues about what's happening?
    Jolaru21
    Threads: 27
    Country:Spain
    2024-09-26, 12:06 PM
    Hey! don't worry.
    Yes, I checked, but there is no log about that, because it's just a reescan. In my case, it doesn't generate logs for a scan...
    Dunno what to do, but I think I wrote a case about this a year ago and was exactly the same issue.
    Jolaru21
    Threads: 27
    Country:Spain
    2024-09-26, 08:23 PM
    anyone knows how can I force logs for this, in order to check what's happening?
    2024-09-26, 08:26 PM
    You can edit logging.default.json. I don't know which OS your server is running but here are the common locations.
    Linux: /etc/jellyfin/
    Docker: /config/config/
    Windows: C:\ProgramData\Jellyfin\Server\config
    Edit the top section to look like this.
        "Serilog": {
            "MinimumLevel": {
                "Default": "Debug",
                "Override": {
                    "Microsoft": "Debug",
                    "System": "Debug"
    Replace "Information" and "Warning" with "Debug". Once you save the file the change in log level should immediately take effect. No need to restart.
