    Jellyfin Forum Support Troubleshooting SOLVED: remote jellyfin Jellyfin.Api.Auth.CustomAuthenticationHandler problem
    ahmad
    Country:Jordan
    2024-03-11, 06:12 AM
    i have a jellyfin in a docker container with domian and cloudflare for remote access when watching a movie or a show after some time it stop playing and can't do anything in the webpage and after refresh i got this first image, so i have to close the tab re-enter the domian for it and login again
    here the log from portainer:
    [code][07:41:06] [INF] [41] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
    [07:41:06] [INF] [46] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/media/Books
    [07:41:06] [INF] [202] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/media/TVSeries/Series
    [07:41:06] [INF] [116] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/media/Movies
    [07:45:00] [INF] [37] Jellyfin.Api.Auth.CustomAuthenticationHandler: CustomAuthentication was not authenticated. Failure message: Invalid token.
    [07:41:06] [INF] [50] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/media/TVSeries/Anime
    [07:41:06] [INF] [74] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/media/Music
    [07:45:00] [INF] [37] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: CustomAuthentication was challenged.
    [07:50:00] [INF] [70] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: CustomAuthentication was challenged.
    [07:50:00] [INF] [70] Jellyfin.Api.Auth.CustomAuthenticationHandler: CustomAuthentication was not authenticated. Failure message: Invalid token.
    [07:41:06] [INF] [41] Emby.Server.Implementations.ScheduledTasks.TaskManager: Scan Media Library Completed after 0 minute(s) and 10 seconds[/code]
    here a brief info about my setup:
    cpu: ryzen 3 3200g
    igpu: amd redaon vega
    ram: 16GB
    OS: Debian 12
    Jellyfin version: 10.8.13
    i run jellyfin inside a docker container with an nginx proxy manager with force SSL for remote access and i register a domain with cloudflare and enabled Proxied
    2024-03-11, 04:30 PM
    I've updated our Nginx Proxy Manager docs recently.
    https://jellyfin.org/docs/general/networ...xy-manager
    Double check your setup lines up with our docs. If it does, we can do some additional troubleshooting.
    ahmad
    Country:Jordan
    2024-03-26, 11:34 AM (This post was last modified: 2024-03-26, 11:36 AM by ahmad. Edited 1 time in total.)
    (2024-03-11, 04:30 PM)TheDreadPirate Wrote: I've updated our Nginx Proxy Manager docs recently.
    Thanks, this works for me.
    gbomacfly
    2025-04-09, 04:32 PM
    Hello!
    I have the same problem.
    My computer is running on Proxmox with an OpenMediaVault VM. It contains a Docker container for Jellyfin. Everything works fine, but I keep getting the same error messages, namely three lines:
    [18:10:04] [INF] [21] Jellyfin.Api.Auth.CustomAuthenticationHandler: CustomAuthentication was not authenticated. Failure message: Invalid token.
    [18:10:04] [INF] [21] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: CustomAuthentication was challenged.
    My Nginx Proxy Manager is configured as described in the documentation. But when I disable the proxy host or quit NPM, the error persists.
    The debug log also doesn't provide any clues as to the source of the error. An IP or hostname would be helpful.
    Can someone please help me? I'm running out of ideas.
    2025-04-09, 05:20 PM
    This is unrelated to Nginx. This is likely a TV client, Android TV or Roku, that has an expired authentication token. You need to find the offending client and log out and log back in on that TV client.
    gbomacfly
    2025-04-10, 06:16 PM
    THX, had found the issue. It was an abandoned Home assistant Container Smiling-face
