    Jellyfin Forum Support Troubleshooting Startup problem jellyfin-web
    There is no way to start the service Jellyfin
    2023-11-22, 05:13 PM
    sudo ps -ef | grep jellyfin
    Can you copy the text here instead of imgur? As long as it isn't a huge amount of text.
    AEZAKMI
    Country:Turkey
    #12
    2023-11-23, 03:00 AM
    dmitry 5856 3170 0 07:58 pts/0 00:00:00 grep jellyfin
    That's what the team gave out, thank you
    2023-11-23, 03:29 AM
    Something is going on with your setup that is preventing it from starting up. Do you have SELinux running or something?
    AEZAKMI
    Country:Turkey
    #14
    2023-11-23, 03:57 AM
    Debian installed by default without a GUI, transmission is installed there, samba how can I still check why it doesn't start, please tell me if there are any other options? Thank you for helping.
    2023-11-23, 06:32 PM
    What is the output of
    sudo systemctl status apparmor
    AEZAKMI
    Country:Turkey
    #16
    2023-11-24, 07:24 AM
    ● apparmor.service - Load AppArmor profiles
    Loaded: loaded (/lib/systemd/system/apparmor.service; enabled; preset: enabled)
    Active: active (exited) since Thu 2023-11-23 12:36:55 +05; 23h ago
    Docs: man:apparmor(7)
    https://gitlab.com/apparmor/apparmor/wikis/home/
    Process: 402 ExecStart=/lib/apparmor/apparmor.systemd reload (code=exited, status=0/SUCCESS)
    Main PID: 402 (code=exited, status=0/SUCCESS)
    CPU: 99ms
    ноя 23 12:36:54 nas systemd[1]: Starting apparmor.service - Load AppArmor profiles...
    ноя 23 12:36:54 nas apparmor.systemd[402]: Restarting AppArmor
    ноя 23 12:36:54 nas apparmor.systemd[402]: Reloading AppArmor profiles
    ноя 23 12:36:55 nas systemd[1]: Finished apparmor.service - Load AppArmor profiles.
    2023-11-24, 06:28 PM
    Honestly, I have no idea what is causing jellyfin to not start. Sorry.
    AEZAKMI
    Country:Turkey
    #18
    2023-11-25, 10:49 AM
    It's a pity that no one can understand me, well, now I tried to install and run the qbittrorent-nox systemctl service and it also gives an error, something with the Operating system I don't even know what to do =(
    AEZAKMI
    Country:Turkey
    #19
    2023-11-25, 01:09 PM
    after all, I corrected the service, maybe someone has some solution to my problem, I will be grateful and thank you very much who will put something
    AEZAKMI
    Country:Turkey
    #20
    2023-11-25, 01:17 PM
    who can tell me how I can open the config file of the systemctrl jellyfin file being run?
