    Jellyfin Forum Support Troubleshooting youtube library will not load
    gaming09
    Threads: 27
    2025-10-24, 10:13 AM
    Is there a new youtube library plugin, since updating to 10.11 the youtube library wont reload, adn i looked at the project it hasnt been updated in over 2 years.is there a new repo?
    Stats:
    JF running on Unraid Docker
    Library Transcoded to h265 mkv via TDARR
    Ram Drive Transcode
    5950x
    a770
    60tb
    dreamon
    Country:Turkey
    2025-10-24, 12:18 PM (This post was last modified: 2025-10-24, 12:22 PM by dreamon. Edited 3 times in total.)
    you don't actually need a plugin for youtube videos.
    jellyfin itself is able to show and play any video sourced from youtube (or any other popular free streaming platform) with metadata and screenshot as long as you have the metadata itself embedded to / alongside the video files.
    there are a few popular open source apps you can use to gather metadata and thumbnails.
    here's the important part: create a "Music Videos" library, thumbnails would only show up in library view correctly when you choose that library type. make sure metadata is readily available your videos. then all of them will be ready for your viewing.
    your videos has to be in .mp4 format, mkv can't keep metadata. if you want, you can also use Mp3Tag to add metadata to mp4 files.
    gaming09
    Threads: 27
    2025-10-24, 05:54 PM
    (2025-10-24, 12:18 PM)dreamon Wrote: you don't actually need a plugin for youtube videos.
    I tired this and still nothing it just the circle of death, ive tried del and re-adding, renaming the files. that library just will not load
    Stats:
    Ram Drive Transcode
    5950x
    a770
    60tb
    gaming09
    Threads: 27
    2025-10-27, 03:49 AM
    https://imgur.com/Y4hPpUh
    this is an example of my library, ive tried every library type.
    and it keeps just spinnning and never loading
    upgraded to 10.11.1 and same thing
    i have all the metadata i just want it to load
    Stats:
    Ram Drive Transcode
    5950x
    a770
    60tb
