    Jellyfin Forum Support Troubleshooting direct play quality issues
    ijhhdboxywgtumogcq
    2024-01-28, 05:56 PM
    Hi all,
    Just a quick question.
    I'm trying to switch from plex to jellyfin, but I feel as if the movie playback quality is less than on plex.
    Here is a side by side, both are directly playing from the local network.
    [Image: FRA0AHn.png]
    https://i.imgur.com/FRA0AHn.png
    when looking at the sky, you can clearly see the steps in color, it's almost as if the bitrate is not high enough but when looking at the playback info, it looks fine.
    in the quality menu, it clearly says "auto - direct", so i'm not sure what i'm missing.
    Is there a way to force full quality direct play?
    Thanks
    tmsrxzar
    2024-01-28, 06:13 PM
    direct is direct, up to the client at that point
    what device/clients are you using?
    2024-01-28, 07:03 PM
    Click on the gear and click Playback Info and double check it is actually direct playing.
    ijhhdboxywgtumogcq
    2024-01-28, 07:06 PM (This post was last modified: 2024-01-28, 07:07 PM by ijhhdboxywgtumogcq. Edited 1 time in total.)
    running the linuxserver jellyfin docker image (I assume this won't be an issue right?)
    Server: 04f859780d09
    Version: 10.8.13
    client is the jellyfin-media-player v1.9.1 on NixOS
    And honestly, whenever I play it in browser with the highest quality and bitrate, it is a lot less noticeable.
    and it is
    [Image: AOTGpcq.png]
    2024-01-28, 07:35 PM (This post was last modified: 2024-01-28, 07:35 PM by TheDreadPirate.)
    I'm not at home at the moment. Don't have access to JMP until tomorrow afternoon (US EST). Click on your icon in the top right and click on client settings. There are some rendering related settings in there you can fiddle with. If you can't figure it out I will try poke around tomorrow.
    ijhhdboxywgtumogcq
    2024-01-28, 07:51 PM (This post was last modified: 2024-01-28, 08:06 PM by ijhhdboxywgtumogcq. Edited 1 time in total.)
    Thanks! Yeah, I looked into it already. Had to turn everything off under the video section to get direct play working. decode.disabled, sync.resample, cache default and aspect normal. transcoding,deinterlace and refreshrate autoswitch turned off.
    Edit: alright, it might be host/client specific issue. Just installed the player via brew on an old macbook. looks much better with the same default player settings.
    I'll have to look into it more. might be just the packages player for my distro, or i wouldn't be surprised it's some more wayland shenanigans.
    Thx for the help
    2024-01-29, 09:13 PM
    I couldn't find any discernible difference in quality except that decode.copy was stuttery.
    Client Settings > HardwareDecoding > decode.enable
    Playback settings > Prefer fMP4-HLS enabled (not the one in the dashboard)
    Does it still direct play with those settings?
    ijhhdboxywgtumogcq
    2024-01-30, 07:40 PM
    Still plays directly, but I don't see any quality changes.
    It's probably just how my system is set up, not even the settings.
    I tested in on a completely different Wayland build under Sway, and the quality is considerably better (but still not super crisp)
    I guess I'll just have to live with it.
    Thx for your time.
    tmsrxzar
    2024-01-30, 08:03 PM
    (2024-01-30, 07:40 PM)ijhhdboxywgtumogcq Wrote: I tested in on a completely different Wayland build under Sway, and the quality is considerably better (but still not super crisp)
    Thx for your time.
    (2024-01-28, 07:06 PM)ijhhdboxywgtumogcq Wrote: [Image: AOTGpcq.png]
    i'm really not sure how much you can expect out of 9Mbit SDR video
    2024-01-30, 08:57 PM (This post was last modified: 2024-01-30, 08:57 PM by TheDreadPirate.)
    My understanding is that the same video is rendered differently between Plex's player and Jellyfin's player. With notable banding in gradients on Jellyfin.
    I'm wondering if Plex Media Player is doing some sort of post processing and Jellyfin is just displaying the video as is.
