    Jellyfin Forum Support Troubleshooting direct play quality issues
    ijhhdboxywgtumogcq
    2024-01-31, 05:14 PM (This post was last modified: 2024-01-31, 05:15 PM by ijhhdboxywgtumogcq. Edited 1 time in total.)
    I doubt it. In vlc I have the slightest bit (not even noticeable, until I actually started checking) of banding and in mpv it is completely fine (under Wayland). Just for testing sake, I used my old X environment, and the video looked completely fine.
    So it's either my wayland or graphics setup/session or the jellyfin media player not playing nice with wayland.
    The weird thing is that it's never really consistent between applications.
    mikesulsenti
    Loonix Expert & Mod
    2024-01-31, 05:45 PM
    Wish I had my Linux workstation setup to test this. The Jellyfin Media Player, I'm pretty sure, is utilizing MPV underneath it.
    Is it installed via Flathub or .deb from the github?
    JellyFin: 10.10.0
    OS: Proxmox 8 + Ubuntu 24.04
    CPU: 2xIntel Xeon E5-2690 v4 (28c/56t)
    RAM: 256GB DDR4
    GPU: Intel Arc A380
    Rack: HPE DL380 Gen9
    Storage: 260TB
      100TB ZFS RAIDZ3 HDD
      150TB ZFS RAIDZ3 HDD
      5TB ZFS RAIDZ1 NVMe
      5TB ZFS RAIDZ3 SSD
    ijhhdboxywgtumogcq
    2024-01-31, 06:14 PM (This post was last modified: 2024-01-31, 06:37 PM by ijhhdboxywgtumogcq. Edited 1 time in total.)
    My distro uses the Github version, but I've also tested the flatpak which has the same issue. It indeed uses mpv underneath the hood, but as you can see from my initial screenshot, the quality difference is noticeable between the player and mpv (same quality as plex).
    2024-01-31, 06:31 PM (This post was last modified: 2024-01-31, 06:31 PM by TheDreadPirate.)
    My understanding is that MPV in Jellyfin Media Player renders differently than MPV does.
    But we do have Jellyfin-MPV Shim that has a different render pipeline than JMP.
    https://github.com/jellyfin/jellyfin-mpv-shim
    Give that a try. There are flatpaks for Linux.
    ijhhdboxywgtumogcq
    2024-01-31, 06:49 PM
    Thanks for the suggestion!
    Just set it up and made it auto cast, works great!
    Not an ideal solution to the problem, but I can live with it.
