    Jellyfin Forum Support General Questions How to start Jellyfin without login on window
    krlsantcard
    2023-09-09, 03:48 PM
    hello, im using jellyfin server on window 10, and kodi (libreelec) on mi TV.
    there's any way that jellyfin start when i turn on the PC. Actually i have to log in on window.
    I made a task on window but it doesnt work fine, some time start the server but other dont.
    Threads: 12
    2023-09-09, 04:23 PM
    You can do a system service install of Jellyfin instead of the basic install. But that requires extra configuration so that the system user has access to your GPU for transcoding. I can't find documentation for how to do that.
    Jellyfin 12.2 (Docker)
    krlsantcard
    2023-09-09, 04:43 PM
    I try it but never work, I was thinking using a docker, but in the end, I must login too. Or not?
    JRPGod
    2023-09-10, 05:29 AM
    I had a lot of issue with getting Jellyfin to register as a service.
    My solution was to ensure Windows is configured to log in to the user on start-up (there's plenty of guides on google for that), and then to start Jellyfin with a batch script that I create a shortcut of and place in the startup folder. Yes I get the ugly cmd window, but at least it works.
    krlsantcard
    2023-09-13, 05:02 PM
    (2023-09-10, 05:29 AM)JRPGod Wrote: I had a lot of issue with getting Jellyfin to register as a service.
    thanks, i hope to find some other way, but it work.!!!
