    Jellyfin Forum Support Troubleshooting Jellyfin not starting up after upgrading to 10.9.0
    Pages (3): 1 2 3 Next »
    Sarinz
    Country:India
    2024-05-12, 10:24 PM
    I got watchtower set up and it updated jellyfin docker image to 10.9.0 .
    jellyfin is running on:
    • docker
    • raspberry pi 4 (Raspberry pi os, arm 64 bit)
    I had migrated from linux to docker by copying the metadata and other config directories and binding them to the container:
    • JELLYFIN_CACHE_DIR = /var/cache/jellyfin
    • JELLYFIN_CONFIG_DIR = /etc/jellyfin
    • JELLYFIN_DATA_DIR = /var/lib/jellyfin
    • JELLYFIN_FFMPEG = /usr/lib/jellyfin-ffmpeg/ffmpeg
    • JELLYFIN_LOG_DIR = /var/log/jellyfin
    • JELLYFIN_WEB_DIR = /jellyfin/jellyfin-web
    • /portainer/Files/AppData/Config/Jellyfin/cache = /var/cache/jellyfin
    • /portainer/Files/AppData/Config/Jellyfin/data = /var/lib/jellyfin
    • /portainer/Files/AppData/Config/Jellyfin/log = /var/log/jellyfin
    • /portainer/Files/AppData/Config/Jellyfin/config = /etc/jellyfin
    • 12f7f294e24e1638850e39836c5fcdd8e10211b828f8559b29ffe44bb785f356 = /config
    • f3266b47e63630fe8a8d14d90873601ffb0ad06b9789118164ad9ed876bf6977 = /cache
    • /mnt/hoarder = /mnt/hoarder
    • /mnt/hulk = /mnt/hulk
    after the upgrade I am getting this error
    [21:41:35] [INF] Applying migration 'MigrateRatingLevels'
    [21:41:36] [INF] Library database backed up to /var/lib/jellyfin/data/library.db.bak40
    [21:41:36] [INF] Recalculating parental rating levels based on rating string.
    [21:41:37] [ERR] Could not apply migration 'MigrateRatingLevels'
    Microsoft.Data.Sqlite.SqliteException (0x80004005): SQLite Error 11: 'database disk image is malformed'.
      at Microsoft.Data.Sqlite.SqliteException.ThrowExceptionForRC(Int32 rc, sqlite3 db)
      at Microsoft.Data.Sqlite.SqliteDataReader.NextResult()
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader(CommandBehavior behavior)
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteReader()
      at Microsoft.Data.Sqlite.SqliteCommand.ExecuteNonQuery()
      at Emby.Server.Implementations.Data.SqliteExtensions.Execute(SqliteConnection sqliteConnection, String commandText)
      at Jellyfin.Server.Migrations.Routines.MigrateRatingLevels.Perform()
      at Jellyfin.Server.Migrations.MigrationRunner.PerformMigrations(IMigrationRoutine[] migrations, MigrationOptions migrationOptions, Action`1 saveConfiguration, ILogger logger)
    [21:41:37] [FTL] Error while starting server
      at Jellyfin.Server.Migrations.MigrationRunner.Run(CoreAppHost host, ILoggerFactory loggerFactory)
      at Jellyfin.Server.Program.StartServer(IServerApplicationPaths appPaths, StartupOptions options, IConfiguration startupConfig)
    [21:41:37] [INF] Running query planner optimizations in the database... This might take a while
    [21:41:37] [INF] Disposing CoreAppHost
    [21:41:37] [INF] Disposing MusicBrainzArtistProvider
    [21:41:37] [INF] Disposing MusicBrainzAlbumProvider
    [21:41:37] [INF] Disposing PluginManager
    I don't know what to do.. I have tried setting the image version to 10.8.13, but that gave many errors, It seemed that 10.9.0 update have changed a lot of things.
    2024-05-13, 01:18 AM
    Upgrading to 10.9 is one way. You cannot revert unless you restore from a backup.
    We JUST released 10.9.1 and I think one of the fixes is for this error you saw.
    Try updating your image to 10.9.1 and see if that resolves this issue.
    Sarinz
    Country:India
    2024-05-13, 07:38 AM
    I have updated the image to 10.9.1, but the issue persists
    [07:26:03] [INF] Jellyfin version: 10.9.1
    [07:26:04] [INF] Environment Variables: ["[JELLYFIN_CACHE_DIR, /var/cache/jellyfin]", "[JELLYFIN_CONFIG_DIR, /etc/jellyfin]", "[JELLYFIN_LOG_DIR, /var/log/jellyfin]", "[DOTNET_SYSTEM_GLOBALIZATION_INVARIANT, 1]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_DATA_DIR, /var/lib/jellyfin]"]
    [07:26:04] [INF] Arguments: ["/jellyfin/jellyfin.dll", "--ffmpeg", "/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    [07:26:04] [INF] Operating system: Debian GNU/Linux 12 (bookworm)
    [07:26:04] [INF] Architecture: Arm64
    [07:26:04] [INF] 64-Bit Process: True
    [07:26:04] [INF] User Interactive: True
    [07:26:04] [INF] Processor count: 4
    [07:26:04] [INF] Program data path: /var/lib/jellyfin
    [07:26:04] [INF] Log directory path: /var/log/jellyfin
    [07:26:04] [INF] Config directory path: /etc/jellyfin
    [07:26:04] [INF] Cache path: /var/cache/jellyfin
    [07:26:04] [INF] Web resources path: /jellyfin/jellyfin-web
    [07:26:04] [INF] Application directory: /jellyfin/
    [07:26:04] [INF] Setting cache path: /var/cache/jellyfin
    [07:26:04] [INF] Loading assemblies
    [07:26:05] [INF] Loaded assembly Jellyfin.Plugin.AniDB, Version=7.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/AniDB_7.0.0.0/Jellyfin.Plugin.AniDB.dll
    [07:26:05] [INF] Skipping disabled plugin 6.0.0.0 of Bookshelf
    [07:26:05] [INF] Skipping disabled plugin 8.0.0.0 of Bookshelf
    [07:26:05] [INF] Skipping disabled plugin 9.0.0.0 of Bookshelf
    [07:26:05] [INF] Skipping disabled plugin 10.0.0.0 of Bookshelf
    [07:26:05] [INF] Loaded assembly Jellyfin.Plugin.Fanart, Version=10.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/Fanart_10.0.0.0/Jellyfin.Plugin.Fanart.dll
    [07:26:05] [INF] Loaded assembly Jellyfin.Plugin.FinTube, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/FinTube_1.0.0.0/Jellyfin.Plugin.FinTube.dll
    [07:26:05] [INF] Skipping disabled plugin 0.1.7.0 of Intro Skipper
    [07:26:05] [INF] Skipping disabled plugin 10.7.7.0 of Merge Versions
    [07:26:05] [INF] Skipping disabled plugin 10.8.0.1 of Merge Versions
    [07:26:05] [INF] Skipping disabled plugin 10.8.0.2 of Merge Versions
    [07:26:05] [INF] Skipping disabled plugin 1.0.0.0 of OPDS
    [07:26:05] [INF] Loaded assembly Jellyfin.Plugin.OpenSubtitles, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/Open Subtitles_19.0.0.0/Jellyfin.Plugin.OpenSubtitles.dll
    [07:26:05] [INF] Skipping disabled plugin 12.0.0.0 of Playback Reporting
    [07:26:05] [INF] Skipping disabled plugin 13.0.0.0 of Playback Reporting
    [07:26:05] [INF] Loaded assembly Jellyfin.Plugin.SkinManager, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/jellyfin/plugins/Skin Manager_2.0.1/Jellyfin.Plugin.SkinManager.dll
    [07:26:05] [INF] Skipping disabled plugin 10.7.0.2 of Theme Songs
    [07:26:05] [INF] Skipping disabled plugin 10.8.0.1 of Theme Songs
    [07:26:05] [INF] Skipping disabled plugin 1.2103.2821.743 of TheMovieDb
    [07:26:05] [INF] Skipping disabled plugin 6.0.0.0 of TheTVDB
    [07:26:05] [INF] Skipping disabled plugin 8.0.0.0 of TheTVDB
    [07:26:05] [INF] Skipping disabled plugin 10.0.0.0 of TheTVDB
    [07:26:05] [INF] Skipping disabled plugin 7.2103.2821.743 of TMDb Box Sets
    [07:26:05] [INF] Skipping disabled plugin 10.0.0.0 of TMDb Box Sets
    [07:26:05] [INF] Skipping disabled plugin 1.0.3.9 of YoutubeMetadata
    [07:26:05] [INF] Defined LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [07:26:05] [INF] Defined LAN exclusions: []
    [07:26:05] [INF] Using LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [07:26:05] [INF] Using bind addresses: ["127.0.0.1", "172.17.0.5"]
    [07:26:05] [INF] Remote IP filter is Allowlist
    [07:26:05] [INF] Filter list: []
    [07:27:27] [INF] Loaded plugin: AniDB 7.0.0.0
    [07:27:27] [INF] Loaded plugin: Fanart 10.0.0.0
    [07:27:27] [INF] Loaded plugin: FinTube 1.0.0.0
    [07:27:27] [INF] Loaded plugin: Open Subtitles 19.0.0.0
    [07:27:27] [INF] Loaded plugin: Skin Manager 2.0.1
    [07:27:27] [INF] Loaded plugin: TMDb 10.9.1.0
    [07:27:27] [INF] Loaded plugin: Studio Images 10.9.1.0
    [07:27:27] [INF] Loaded plugin: OMDb 10.9.1.0
    [07:27:27] [INF] Loaded plugin: MusicBrainz 10.9.1.0
    [07:27:27] [INF] Loaded plugin: AudioDB 10.9.1.0
    [07:27:27] [INF] Applying migration 'MigrateRatingLevels'
    [07:27:28] [INF] Library database backed up to /var/lib/jellyfin/data/library.db.bak92
    [07:27:28] [INF] Recalculating parental rating levels based on rating string.
    [07:27:29] [ERR] Could not apply migration 'MigrateRatingLevels'
    [07:27:29] [FTL] Error while starting server
    [07:27:29] [INF] Running query planner optimizations in the database... This might take a while
    [07:27:29] [INF] Disposing CoreAppHost
    [07:27:29] [INF] Disposing MusicBrainzArtistProvider
    [07:27:29] [INF] Disposing MusicBrainzAlbumProvider
    [07:27:29] [INF] Disposing PluginManager
    riddertommie
    Country:Netherlands
    2024-05-13, 08:21 AM (This post was last modified: 2024-05-13, 08:22 AM by riddertommie. Edited 1 time in total.)
    Same here, using Docker (linuxserver/jellyfin:latest) After yesterday update 10.9 no contact possible with jellyfin server. Normaly I wait for 1 or 2 days to see if tere is a update. This morning there was 10.9.1 but after updating stil no contact with server. I have 1 none related err in the log (i think).
    [10:06:33] [ERR] [1] Emby.Server.Implementations.Plugins.PluginManager: Failed to load assembly /config/data/plugins/Merge Versions_10.8.0.2/Jellyfin.Plugin.MergeVersions.dll. This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    and some warnings
    [10:06:46] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
    [10:06:46] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
    [10:06:46] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {42e09655-9daf-4a43-8afa-5a1979905d56} may be persisted to storage in unencrypted form.
    [10:06:49] [WRN] [1] Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware: The WebRootPath was not found: /run/s6-rc:s6-rc-init:EigKGL/servicedirs/svc-jellyfin/wwwroot. Static files may be unavailable.
    Don't know what to do here, any help welcome.
    2024-05-13, 12:06 PM
    @Sarinz Do you have a backup from 10.8.13?
    @riddertommie Can you share your full log?
    Flaring0281
    Country:Netherlands
    2024-05-13, 01:03 PM
    (2024-05-13, 12:06 PM)TheDreadPirate Wrote: @Sarinz Do you have a backup from 10.8.13?
    I have the same problem as @riddertommie. Can't access Jellyfin even directly through port 8096. I'm using the official Docker image. No backups unfortunately. If I delete the /config and /cache folder, then the web UI and setup wizard loads successfully.
    docker-compose.yaml:
        image: jellyfin/jellyfin
        container_name: jellyfin
        environment:
          - TZ=Europe/Amsterdam
        user: 1000:1000
        group_add:
          - 109
          - /home/me/mediaserver/jellyfin/config:/config
          - /home/me/mediaserver/jellyfin/cache:/cache
          - /media/mergerfs/Series:/media/TV
          - /media/mergerfs/Films:/media/Movies
          - /media/mergerfs/Boeken:/media/Books
        restart: 'unless-stopped'
        networks:
          mediaserv:
            ipv4_address: 172.27.0.100
        ports:
          - 8096:8096
        devices:
    networks:
      mediaserv:
        external: true
    Logs:
    [2024-05-13 14:56:47.636 +02:00] [INF] [1] Main: Jellyfin version: "10.9.1"
    [2024-05-13 14:56:47.659 +02:00] [INF] [1] Main: Environment Variables: ["[JELLYFIN_FFMPEG, /usr/lib/jellyfin-ffmpeg/ffmpeg]", "[JELLYFIN_WEB_DIR, /jellyfin/jellyfin-web]", "[JELLYFIN_CONFIG_DIR, /config/config]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_DATA_DIR, /config]", "[JELLYFIN_CACHE_DIR, /cache]"]
    [2024-05-13 14:56:47.660 +02:00] [INF] [1] Main: Arguments: ["/jellyfin/jellyfin.dll", "--ffmpeg", "/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    [2024-05-13 14:56:47.661 +02:00] [INF] [1] Main: Operating system: "Debian GNU/Linux 12 (bookworm)"
    [2024-05-13 14:56:47.661 +02:00] [INF] [1] Main: Architecture: X64
    [2024-05-13 14:56:47.661 +02:00] [INF] [1] Main: 64-Bit Process: True
    [2024-05-13 14:56:47.661 +02:00] [INF] [1] Main: User Interactive: True
    [2024-05-13 14:56:47.661 +02:00] [INF] [1] Main: Processor count: 4
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Program data path: "/config"
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Log directory path: "/config/log"
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Config directory path: "/config/config"
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Cache path: "/cache"
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Web resources path: "/jellyfin/jellyfin-web"
    [2024-05-13 14:56:47.662 +02:00] [INF] [1] Main: Application directory: "/jellyfin/"
    [2024-05-13 14:56:47.780 +02:00] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: "/cache"
    [2024-05-13 14:56:47.839 +02:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
    [2024-05-13 14:56:47.873 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.Bookshelf, Version=11.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/Bookshelf_11.0.0.0/Jellyfin.Plugin.Bookshelf.dll"
    [2024-05-13 14:56:47.875 +02:00] [ERR] [1] Emby.Server.Implementations.Plugins.PluginManager: Failed to load assembly "/config/plugins/InfuseSync_1.4.2.0/InfuseSync.dll". This error occurs when a plugin references an incompatible version of one of the shared libraries. Disabling plugin
    System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
    Could not load type 'MediaBrowser.Controller.Plugins.IServerEntryPoint' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    Could not load file or assembly 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
      at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
      at System.Reflection.RuntimeModule.GetTypes()
      at Emby.Server.Implementations.Plugins.PluginManager.LoadAssemblies()+MoveNext()
    System.TypeLoadException: Could not load type 'MediaBrowser.Controller.Plugins.IServerEntryPoint' from assembly 'MediaBrowser.Controller, Version=10.9.1.0, Culture=neutral, PublicKeyToken=null'.
    System.IO.FileNotFoundException: Could not load file or assembly 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
    File name: 'SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'
    [2024-05-13 14:56:47.886 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/Playback Reporting_14.0.0.0/SQLitePCL.pretty.dll"
    [2024-05-13 14:56:47.887 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.PlaybackReporting, Version=14.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/Playback Reporting_14.0.0.0/Jellyfin.Plugin.PlaybackReporting.dll"
    [2024-05-13 14:56:47.888 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.SkinManager, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/Skin Manager_2.0.1/Jellyfin.Plugin.SkinManager.dll"
    [2024-05-13 14:56:47.891 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Jellyfin.Plugin.Tvdb, Version=11.0.0.0, Culture=neutral, PublicKeyToken=null" from "/config/plugins/TheTVDB_11.0.0.0/Jellyfin.Plugin.Tvdb.dll"
    [2024-05-13 14:56:47.898 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly "Tvdb.Sdk, Version=4.7.9.1, Culture=neutral, PublicKeyToken=null" from "/config/plugins/TheTVDB_11.0.0.0/Tvdb.Sdk.dll"
    [2024-05-13 14:56:47.953 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2024-05-13 14:56:47.953 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions: []
    [2024-05-13 14:56:47.954 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2024-05-13 14:56:47.954 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: []
    [2024-05-13 14:56:47.954 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Remote IP filter is "Allowlist"
    [2024-05-13 14:56:47.954 +02:00] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filter list: []
    [2024-05-13 14:56:49.427 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Bookshelf" "11.0.0.0"
    [2024-05-13 14:56:49.428 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Playback Reporting" "14.0.0.0"
    [2024-05-13 14:56:49.429 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Skin Manager" "2.0.1"
    [2024-05-13 14:56:49.430 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TheTVDB" "11.0.0.0"
    [2024-05-13 14:56:49.431 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "TMDb" "10.9.1.0"
    [2024-05-13 14:56:49.431 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "Studio Images" "10.9.1.0"
    [2024-05-13 14:56:49.431 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "OMDb" "10.9.1.0"
    [2024-05-13 14:56:49.449 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "MusicBrainz" "10.9.1.0"
    [2024-05-13 14:56:49.450 +02:00] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: "AudioDB" "10.9.1.0"
    [2024-05-13 14:56:49.514 +02:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
    [2024-05-13 14:56:49.515 +02:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
    [2024-05-13 14:56:49.532 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: EventMonitorEntryPoint Running
    [2024-05-13 14:56:49.540 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Sqlite version: 3.41.2
    [2024-05-13 14:56:49.541 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Sqlite compiler options: ATOMIC_INTRINSICS=1,COMPILER=gcc-9.4.0,DEFAULT_AUTOVACUUM,DEFAULT_CACHE_SIZE=-2000,DEFAULT_FILE_FORMAT=4,DEFAULT_FOREIGN_KEYS,DEFAULT_JOURNAL_SIZE_LIMIT=-1,DEFAULT_MMAP_SIZE=0,DEFAULT_PAGE_SIZE=4096,DEFAULT_PCACHE_INITSZ=20,DEFAULT_RECURSIVE_TRIGGERS,DEFAULT_SECTOR_SIZE=4096,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_AUTOCHECKPOINT=1000,DEFAULT_WAL_SYNCHRONOUS=2,DEFAULT_WORKER_THREADS=0,ENABLE_COLUMN_METADATA,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS4,ENABLE_FTS5,ENABLE_MATH_FUNCTIONS,ENABLE_RTREE,ENABLE_SNAPSHOT,MALLOC_SOFT_LIMIT=1024,MAX_ATTACHED=10,MAX_COLUMN=2000,MAX_COMPOUND_SELECT=500,MAX_DEFAULT_PAGE_SIZE=8192,MAX_EXPR_DEPTH=1000,MAX_FUNCTION_ARG=127,MAX_LENGTH=1000000000,MAX_LIKE_PATTERN_LENGTH=50000,MAX_MMAP_SIZE=0x7fff0000,MAX_PAGE_COUNT=1073741823,MAX_PAGE_SIZE=65536,MAX_SQL_LENGTH=1000000000,MAX_TRIGGER_DEPTH=1000,MAX_VARIABLE_NUMBER=32766,MAX_VDBE_OP=250000000,MAX_WORKER_THREADS=8,MUTEX_PTHREADS,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1
    [2024-05-13 14:56:49.553 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Default journal_mode for "/config/data/playback_reporting.db" is "delete"
    [2024-05-13 14:56:49.553 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Initialize PlaybackActivity Repository
    [2024-05-13 14:56:49.562 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: PlaybackActivity table schema OK
    [2024-05-13 14:56:49.562 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Expected : "datecreated:datetime|userid:text|itemid:text|itemtype:text|itemname:text|playbackmethod:text|clientname:text|devicename:text|playduration:int"
    [2024-05-13 14:56:49.562 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Received : "datecreated:datetime|userid:text|itemid:text|itemtype:text|itemname:text|playbackmethod:text|clientname:text|devicename:text|playduration:int"
    [2024-05-13 14:56:49.572 +02:00] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {e631a97d-d5b1-4fce-9cf9-c7c6bdcd4a93} may be persisted to storage in unencrypted form.
    [2024-05-13 14:56:50.230 +02:00] [WRN] [1] Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware: The WebRootPath was not found: "/wwwroot". Static files may be unavailable.
    [2024-05-13 14:56:50.267 +02:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
    [2024-05-13 14:56:50.269 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.TaskCleanDb: TaskCleanDb Loaded
    [2024-05-13 14:56:50.270 +02:00] [INF] [1] Jellyfin.Plugin.PlaybackReporting.TaskRunBackup: TaskRunBackup Loaded
    [2024-05-13 14:56:50.282 +02:00] [INF] [8] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/Movies"
    [2024-05-13 14:56:50.286 +02:00] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory "/media/TV"
    [2024-05-13 14:56:50.294 +02:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Playback Reporting Trim Db" set to fire at 2024-05-14 00:00:00.000 +02:00, which is 09:03:09.7052852 from now.
    [2024-05-13 14:56:50.303 +02:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Trickplay-afbeeldingen genereren" set to fire at 2024-05-14 03:00:00.000 +02:00, which is 12:03:09.6969805 from now.
    [2024-05-13 14:56:50.308 +02:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Hoofdstukafbeeldingen uitpakken" set to fire at 2024-05-14 02:00:00.000 +02:00, which is 11:03:09.6915232 from now.
    [2024-05-13 14:56:50.315 +02:00] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for "Mediabibliotheek scannen" set to fire at 2024-05-14 00:00:00.000 +02:00, which is 09:03:09.6844006 from now.
    [2024-05-13 14:56:50.336 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version "6.0.1"
    [2024-05-13 14:56:50.383 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
    [2024-05-13 14:56:50.400 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available "encoders": ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [2024-05-13 14:56:50.417 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
    [2024-05-13 14:56:50.507 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
    [2024-05-13 14:56:50.661 +02:00] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: "/usr/lib/jellyfin-ffmpeg/ffmpeg"
    [2024-05-13 14:56:50.662 +02:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: "5c77490999f64ea3b24a3edc3e0f9013"
    [2024-05-13 14:56:50.662 +02:00] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
    [2024-05-13 14:56:50.662 +02:00] [INF] [1] Main: Startup complete 0:00:03.1769268
    [2024-05-13 14:56:53.333 +02:00] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Collecties en afspeellijsten opruimen" Completed after 0 minute(s) and 0 seconds
    [2024-05-13 14:56:54.506 +02:00] [INF] [17] Emby.Server.Implementations.ScheduledTasks.TaskManager: "Plug-ins bijwerken" Completed after 0 minute(s) and 1 seconds
    2024-05-13, 01:55 PM
    Yours is starting up fine. Did you clear your browser cache? You can try to ncat your jellyfin server to verify that it is accessible.
    chris@optimus-maximus:~$ nc -vz 192.168.1.3 8096
    Connection to 192.168.1.3 8096 port [tcp/*] succeeded!
    modtx
    Country:Netherlands
    2024-05-13, 02:23 PM
    I think I might be having a similar issue to what is happening here.
    However I am running the linuxserverio image. Not sure if I should be asking here or there?
    I can't see anything in the logs that has gone wrong really but will post the logs here for clarity
    Setting up openmp-extras-runtime (15.54.0.50401-84~20.04) ...
    Setting up libelf-dev:amd64 (0.186-1build1) ...
    Setting up rocm-opencl (2.0.0.50401-84~20.04) ...
    Setting up rocm-language-runtime (5.4.1.50401-84~20.04) ...
    Setting up rocm-opencl-runtime (5.4.1.50401-84~20.04) ...
    update-alternatives: using /opt/rocm-5.4.1/bin/clinfo to provide /usr/bin/clinfo (clinfo) in auto mode
    Processing triggers for libc-bin (2.35-0ubuntu3.7) ...
    [custom-init] No custom files found, skipping...
    [16:11:46] [INF] [1] Main: Jellyfin version: 10.9.1
    [16:11:46] [INF] [1] Main: Environment Variables: ["[JELLYFIN_CONFIG_DIR, /config]", "[JELLYFIN_CACHE_DIR, /config/cache]", "[JELLYFIN_LOG_DIR, /config/log]", "[JELLYFIN_DATA_DIR, /config/data]", "[JELLYFIN_WEB_DIR, /usr/share/jellyfin/web]"]
    [16:11:46] [INF] [1] Main: Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "--ffmpeg=/usr/lib/jellyfin-ffmpeg/ffmpeg"]
    [16:11:46] [INF] [1] Main: Operating system: Ubuntu 22.04.4 LTS
    [16:11:46] [INF] [1] Main: Architecture: X64
    [16:11:46] [INF] [1] Main: 64-Bit Process: True
    [16:11:46] [INF] [1] Main: User Interactive: True
    [16:11:46] [INF] [1] Main: Processor count: 12
    [16:11:46] [INF] [1] Main: Program data path: /config/data
    [16:11:46] [INF] [1] Main: Log directory path: /config/log
    [16:11:46] [INF] [1] Main: Config directory path: /config
    [16:11:46] [INF] [1] Main: Cache path: /config/cache
    [16:11:46] [INF] [1] Main: Web resources path: /usr/share/jellyfin/web
    [16:11:46] [INF] [1] Main: Application directory: /usr/lib/jellyfin/bin/
    [16:11:46] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: /config/cache
    [16:11:47] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly Jellyfin.Plugin.PlaybackReporting, Version=14.0.0.0, Culture=neutral, PublicKeyToken=null from /config/data/plugins/Playback Reporting_14.0.0.0/Jellyfin.Plugin.PlaybackReporting.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly SQLitePCL.pretty, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/data/plugins/Playback Reporting_14.0.0.0/SQLitePCL.pretty.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly DocumentFormat.OpenXml, Version=2.16.0.0, Culture=neutral, PublicKeyToken=8fb06cb64d019a17 from /config/data/plugins/Reports_17.0.0.0/DocumentFormat.OpenXml.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly SixLabors.Fonts, Version=1.0.0.0, Culture=neutral, PublicKeyToken=d998eea7b14cab13 from /config/data/plugins/Reports_17.0.0.0/SixLabors.Fonts.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly ClosedXML, Version=0.97.0.0, Culture=neutral, PublicKeyToken=fd1eb21b62ae805b from /config/data/plugins/Reports_17.0.0.0/ClosedXML.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly ExcelNumberFormat, Version=1.1.0.0, Culture=neutral, PublicKeyToken=23c6f5d73be07eca from /config/data/plugins/Reports_17.0.0.0/ExcelNumberFormat.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly Jellyfin.Plugin.Reports, Version=17.0.0.0, Culture=neutral, PublicKeyToken=null from /config/data/plugins/Reports_17.0.0.0/Jellyfin.Plugin.Reports.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly System.IO.Packaging, Version=4.0.5.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a from /config/data/plugins/Reports_17.0.0.0/System.IO.Packaging.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly MQTTnet.Extensions.ManagedClient, Version=4.3.3.952, Culture=neutral, PublicKeyToken=fdb7629f2e364a63 from /config/data/plugins/Webhook_12.0.0.0/MQTTnet.Extensions.ManagedClient.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly BouncyCastle.Cryptography, Version=2.0.0.0, Culture=neutral, PublicKeyToken=072edcf4a5328938 from /config/data/plugins/Webhook_12.0.0.0/BouncyCastle.Cryptography.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly Jellyfin.Plugin.Webhook, Version=12.0.0.0, Culture=neutral, PublicKeyToken=null from /config/data/plugins/Webhook_12.0.0.0/Jellyfin.Plugin.Webhook.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly MimeKit, Version=4.5.0.0, Culture=neutral, PublicKeyToken=bede1c8a46c66814 from /config/data/plugins/Webhook_12.0.0.0/MimeKit.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly Handlebars, Version=2.1.6.0, Culture=neutral, PublicKeyToken=22225d0bf33cd661 from /config/data/plugins/Webhook_12.0.0.0/Handlebars.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly MQTTnet, Version=4.3.3.952, Culture=neutral, PublicKeyToken=fdb7629f2e364a63 from /config/data/plugins/Webhook_12.0.0.0/MQTTnet.dll
    [16:11:47] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded assembly MailKit, Version=4.5.0.0, Culture=neutral, PublicKeyToken=4e064fe7c44a8f1b from /config/data/plugins/Webhook_12.0.0.0/MailKit.dll
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses: ["192.168.1.110/24"]
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions: []
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: ["192.168.1.110/24"]
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: []
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Remote IP filter is Allowlist
    [16:11:47] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Filter list: []
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Playback Reporting 14.0.0.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Reports 17.0.0.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Webhook 12.0.0.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: TMDb 10.9.1.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Studio Images 10.9.1.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: OMDb 10.9.1.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: MusicBrainz 10.9.1.0
    [16:11:54] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: AudioDB 10.9.1.0
    [16:11:54] [WRN] [1] Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository: Using an in-memory repository. Keys will not be persisted to storage.
    [16:11:54] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data will be unavailable when application exits.
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.EventMonitorEntryPoint: EventMonitorEntryPoint Running
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Sqlite version: 3.41.2
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Sqlite compiler options: ATOMIC_INTRINSICS=1,COMPILER=gcc-9.4.0,DEFAULT_AUTOVACUUM,DEFAULT_CACHE_SIZE=-2000,DEFAULT_FILE_FORMAT=4,DEFAULT_FOREIGN_KEYS,DEFAULT_JOURNAL_SIZE_LIMIT=-1,DEFAULT_MMAP_SIZE=0,DEFAULT_PAGE_SIZE=4096,DEFAULT_PCACHE_INITSZ=20,DEFAULT_RECURSIVE_TRIGGERS,DEFAULT_SECTOR_SIZE=4096,DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_AUTOCHECKPOINT=1000,DEFAULT_WAL_SYNCHRONOUS=2,DEFAULT_WORKER_THREADS=0,ENABLE_COLUMN_METADATA,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS4,ENABLE_FTS5,ENABLE_MATH_FUNCTIONS,ENABLE_RTREE,ENABLE_SNAPSHOT,MALLOC_SOFT_LIMIT=1024,MAX_ATTACHED=10,MAX_COLUMN=2000,MAX_COMPOUND_SELECT=500,MAX_DEFAULT_PAGE_SIZE=8192,MAX_EXPR_DEPTH=1000,MAX_FUNCTION_ARG=127,MAX_LENGTH=1000000000,MAX_LIKE_PATTERN_LENGTH=50000,MAX_MMAP_SIZE=0x7fff0000,MAX_PAGE_COUNT=1073741823,MAX_PAGE_SIZE=65536,MAX_SQL_LENGTH=1000000000,MAX_TRIGGER_DEPTH=1000,MAX_VARIABLE_NUMBER=32766,MAX_VDBE_OP=250000000,MAX_WORKER_THREADS=8,MUTEX_PTHREADS,SYSTEM_MALLOC,TEMP_STORE=1,THREADSAFE=1
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Default journal_mode for /config/data/data/playback_reporting.db is delete
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Initialize PlaybackActivity Repository
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: PlaybackActivity table schema OK
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Expected : datecreated:datetime|userid:text|itemid:text|itemtype:text|itemname:text|playbackmethod:text|clientname:text|devicename:text|playduration:int
    [16:11:54] [INF] [1] Jellyfin.Plugin.PlaybackReporting.Data.ActivityRepository: Received : datecreated:datetime|userid:text|itemid:text|itemtype:text|itemname:text|playbackmethod:text|clientname:text|devicename:text|playduration:int
    [16:11:54] [WRN] [1] Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager: No XML encryptor configured. Key {efbf40c6-879a-44d3-966b-e7a85b16940b} may be persisted to storage in unencrypted form.
    [16:11:55] [WRN] [1] Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware: The WebRootPath was not found: /run/s6-rc:s6-rc-init:PhpMPO/servicedirs/svc-jellyfin/wwwroot. Static files may be unavailable.
    [16:11:55] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
    [16:11:55] [INF] [1] Jellyfin.Plugin.PlaybackReporting.TaskCleanDb: TaskCleanDb Loaded
    [16:11:55] [INF] [1] Jellyfin.Plugin.PlaybackReporting.TaskRunBackup: TaskRunBackup Loaded
    [16:11:55] [INF] [11] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:55] [INF] [15] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:55] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Playback Reporting Trim Db set to fire at 2024-05-14 00:00:00.000 +02:00, which is 07:48:04.6808042 from now.
    [16:11:55] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Generate Trickplay Images set to fire at 2024-05-14 03:00:00.000 +02:00, which is 10:48:04.5973169 from now.
    [16:11:55] [INF] [10] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:55] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Extract Chapter Images set to fire at 2024-05-14 02:00:00.000 +02:00, which is 09:48:04.4026653 from now.
    [16:11:55] [INF] [16] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:55] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Scan Media Library set to fire at 2024-05-14 01:00:00.000 +02:00, which is 08:48:04.0841579 from now.
    [16:11:55] [INF] [8] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:55] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Found ffmpeg version 6.0.1
    [16:11:56] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available decoders: ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
    [16:11:56] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available encoders: ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_v4l2m2m", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "libfdk_aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [16:11:56] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "hwupload_vaapi", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_opencl", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemap_cuda", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale", "alphasrc"]
    [16:11:56] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Available hwaccel types: ["cuda", "vaapi", "qsv", "drm", "opencl", "vulkan"]
    [16:11:56] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: /usr/lib/jellyfin-ffmpeg/ffmpeg
    [16:11:56] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: 71ba1eac62be4c50976c191d02760bce
    [16:11:56] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
    [16:11:56] [INF] [1] Main: Startup complete 0:00:10.2981215
    [16:11:56] [INF] [17] Emby.Server.Implementations.IO.LibraryMonitor: Watching directory /data/...
    [16:11:58] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Clean up collections and playlists Completed after 0 minute(s) and 0 seconds
    [16:12:00] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Update Plugins Completed after 0 minute(s) and 1 seconds
    [16:12:55] [INF] [17] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:13:25] [INF] [16] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:13:55] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:14:25] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:14:55] [INF] [14] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:15:25] [INF] [15] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:15:55] [INF] [14] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:16:25] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:16:55] [INF] [17] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:17:25] [INF] [19] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    [16:17:55] [INF] [8] Emby.Server.Implementations.ScheduledTasks.TaskManager: Webhook Item Added Notifier Completed after 0 minute(s) and 0 seconds
    The last log just repeats the whole time for some reason
    I have tried stopping the container and running docker system prune -a and restarting it but I still cannot access the container at all.
    Any ideas?
    Flaring0281
    Country:Netherlands
    2024-05-13, 02:28 PM
    (2024-05-13, 01:55 PM)TheDreadPirate Wrote: Yours is starting up fine.  Did you clear your browser cache?  You can try to ncat your jellyfin server to verify that it is accessible.
    Fixed it by deleting config/config/network.xml. It seems to be binding to the correct IP address now.
    modtx
    Country:Netherlands
    2024-05-13, 02:32 PM
    You legend. This actually worked for me as well
