    Jellyfin Forum Support Troubleshooting SOLVED: Help with transcoding
    Pages (3): 1 2 3 Next »
    Slow transcoding issue.
    Deegee88
    2024-06-06, 05:01 PM
    Hello - i've recently moved my server over to ubuntu desktop and installed jellyfin via a portainer stack.
    I have an A380 which i'm trying to set up for encoding but it seems very sluggish.
    Stack code:
        container_name: jellyfin
        environment:
          - PUID=1000
          - PGID=1000
          - TZ=Europe/London
          - JELLYFIN_PublishedServerUrl=192.168.4.86 #optional
          - /mnt/programs/jellyfinConfused-faceconfig
          - /mnt/programs/jellyfin/cacheConfused-facecache
          - /mnt/vault/showsConfused-faceshows
          - /mnt/vault/filmsConfused-facefilms
        ports:
          - 8096:8096
          - 7359:7359/udp #optional
          - 1900:1900/udp #optional
        devices:
          - /dev/dri/renderD128Confused-facedev/dri/renderD128
        restart: unless-stopped
    Transcode log: https://sourceb.in/1pQo3NECMk
    My system does have dual GPU's but i'm 90% sure that D128 is the A380 and not the other GPU (K2200 i believe).
    Any help on what i'm doing wrong would be appreciated.
    Jellyfin 10.10.3
    Ubuntu Desktop LTS 24.04
    Intel Xeon E5-1650 v3
    64GB DDR4
    2024-06-06, 05:05 PM (This post was last modified: 2024-06-06, 05:06 PM by TheDreadPirate. Edited 1 time in total.)
    Just pass in /dev/dri in its entirety. The Intel driver will then automatically select your Arc GPU. In a multi-GPU setup, which GPU gets assigned to which renderD number is random on reboots.
    devices:
          - /dev/dri/:/dev/dri/
    Deegee88
    2024-06-06, 05:23 PM (This post was last modified: 2024-06-06, 05:26 PM by Deegee88.)
    So as long as i have Intelquick sync selected in hardware encoding it'll know to use the A380?
    At the moment I have HVEC, H264, VC1, AV1, HEVC 10bit & VP9 10bit selected to be decoded.
    and encoding format is just HEVC - not AV1
    Does that sound okay?
    https://sourceb.in/IUCxzrlP3h
    It is still extremely slow...
    https://sourceb.in/DDpGovDOlc - another film title which is exactly the same.
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-06, 05:28 PM
    Correct. The Intel driver will automatically select your Arc GPU if you just pass in /dev/dri without specifying a particular renderD device.
    Why not enable AV1 encoding?
    Also, VC1 decoding is not supported. This table has all the codecs that Intel supports (the far right column).
    https://en.wikipedia.org/wiki/Intel_Quic...d_encoding
    Everything except VP8 and VC1.
    Deegee88
    2024-06-06, 05:37 PM
    No particular reason it was just setup that way.
    Unforunately even with AV1 encoding and changing to /dev/dri it's still very slow.
    It's actually quicker to disable hardware acceleration - which defeats the point surely?
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-06, 05:56 PM
    Can you share the ffmpeg log from the "slow" transcode?
    Deegee88
    2024-06-06, 06:04 PM
    Yup - i did post them above but here are 2:
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-06, 06:13 PM
    Enable low power encoding (both check boxes). Its required for Arc.
    Deegee88
    2024-06-06, 06:19 PM
    Okay - so that has helped a bit but still not perfect. Compared to no hardware acceleration with speeds of 1.5 i'm not getting 0.4 (so double what it was!) but still with some buffering - especially when first starting up.
    https://srcb.in/VSwr8VxCus
    Is this normal?
    Jellyfin 10.10.3
    64GB DDR4
    2024-06-06, 06:31 PM
    What kernel is your system running?  sudo uname -a
    BTW, this is what you should be seeing.
