    Jellyfin Forum Support Troubleshooting SOLVED: Jellyfin will not work on fresh install.
    On install, jellyfin will not work. Connecting to the website will only time out.
    felines54
    7 hours ago
    Hey all, I've been trying to install Jellyfin on my Debian 12 machine, but I haven't been able to get it working. When installed, everything works fine on the server side. Systemctl says its enabled and running, logs say that everything works fine, but when I try to access it on my web browser, it times out no matter what I do.
    I've tried reinstalling, restarted services, rebooted my server, none of it works. Logs even point to it just completely working entirely, but there's still no web output.
    Here's my specs:
    OS: Debian 13
    CPU: AMD FX-4300
    GPU: AMD Radeon RX 460
    Memory: 16GB
    Jellyfin was installed using the shell installer and is NOT being used through a docker container.
    Logs: https://pastebin.com/XHUATEfS
    Any help would be appreciated, thanks in advance!
    Duvel
    Country:Belgium
    5 hours ago
    You server is running.
    The only explanation is either :
    1. Firewall blocking (what's the state of ufw on the server ????)
    2. You dont specify the right port.
    jimmyjammy
    3 hours ago
    Make sure you clear your browser cache before accessing the server in your browser
    felines54
    53 minutes ago (This post was last modified: 50 minutes ago by felines54. Edited 1 time in total.)
    Oh my god, it was the firewall. Never had a firewall issue when installing this on other systems (didn't even know firewalld was enabled), so this was new to me.
    I just allowed ports 8096/tcp, 8920/tcp, and 7359/udp through firewalld and it all went through smoothly. Thanks for the help!
    Users browsing this thread: 9 Guest(s)
