    Jellyfin Forum Support Troubleshooting SOLVED: Local Connection Issue
    Pages (3): 1 2 3 Next »
    Cannot connect devices on LAN to host server
    sammyg2005
    2024-07-23, 08:13 PM
    I have read numerous forums and articles trying to get this to work and have not suceeded. Like many, I can connect to the WebUI on the host machine with localhost and the IP 192.168.31.xxx. Any assistance is appreciated.
    Docker compose YAML
    networks:
      mediastack:
        driver: bridge
        ipam:
          driver: default
          config:
          - subnet: ${DOCKER_SUBNET:?err}
            gateway: ${DOCKER_GATEWAY:?err}
    #  jellyfin:
    #    external: true
    #    driver: bridge
    #    ipam:
    #      driver: default
      gluetun:
        image: qmcgaw/gluetun
        container_name: gluetun
        restart: always
        cap_add:
          - NET_ADMIN
        devices:
          - /dev/net/tun:/dev/net/tun
        ports:
          - 8888:8888/tcp # HTTP proxy
          - 8388:8388/tcp # Shadowsocks
          - 8388:8388/udp # Shadowsocks
          - 8080:8080/tcp # gluetun
          - "${WEBUI_PORT_QBITTORRENT:?err}:${WEBUI_PORT_QBITTORRENT:?err}"  # WebUI Portal: qBittorrent
          - ${APPDATA:?err}/gluetun:/config
        environment:
          - PUID=${PUID:?err}
          - PGID=${PGID:?err}
          - TZ=${TIMEZONE:?err}
          - VPN_TYPE=${VPN_TYPE:?err}
          - VPN_SERVICE_PROVIDER=${VPN_SERVICE_PROVIDER:?err}
          - OPENVPN_USER=${VPN_USERNAME:?err}
          - OPENVPN_PASSWORD=${VPN_PASSWORD:?err}
          - VPN_PORT_FORWARDING_USERNAME=${VPN_USERNAME:?err}
          - VPN_PORT_FORWARDING_PASSWORD=${VPN_PASSWORD:?err}
          - VPN_PORT_FORWARDING=on
          - SERVER_COUNTRIES=${SERVER_COUNTRIES}
          #- SERVER_REGIONS=$(SERVER_REGIONS)
          #- SERVER_CITIES=$(SERVER_CITIES)
          #- SERVER_HOSTNAMES=$(SERVER_HOSTNAMES)
          - OPENVPN_CIPHERS=AES-256-GCM
        networks:
          - mediastack
        container_name: jellyfin
        network_mode: "host"
        restart: unless-stopped
    # Add Configurations for GPU Hardware Rendering Here:
        devices:
          - /dev/dri/card1:/dev/dri/card1
          - ${APPDATA:?err}/jellyfin:/config
          - ${MEDIADATA:?err}/:/data/media/
        ports:
          - 8096:8096
          - 7359:7359/udp      # Enable for DLNA - Only works on HOST Network Mode
          - 1900:1900/udp      # Enable for DLNA - Only works on HOST Network Mode
        environment:
          - PUID=${PUID:?err}
          - PGID=${PGID:?err}
          - UMASK=${UMASK:?err}
          - JELLYFIN_PublishedServerUrl=${LOCAL_DOCKER_IP:?err}  # Enable for DLNA - Only works on HOST Network Mode
    #    networks:
    #      - jellyfin
    Host OS: Arch
    Subnet: 192.168.30.0/23
    Server IP: 192.168.31.xxx
    Jellyfin install method: Docker with compose stack
    Devices tried to connect to server: Firestick, Laptop running Mint, and iOS device with latest version
    App used: Official Jellyfin Mobile, AndroidTV Jellyfin app
    Things tried:
    - host and bridge mode in docker compose
    - numerous restarts
    - open ports in host firewall
    - multiple network settings in Jellyfin
    2024-07-23, 08:35 PM (This post was last modified: 2024-07-23, 08:37 PM by TheDreadPirate. Edited 1 time in total.)
    Comment out this block.
    ports:
          - 8096:8096
    Since you are using host networking for the jellyfin container, they are not needed.
    Can you share the output of "sudo docker inspect jellyfin" and "sudo ufw status verbose"? I want to confirm the output of the command line UFW with what whatever UI you are looking at. What UI is that anyway? Docker Desktop or something?
    Unrelated to the root problem, your firewall rule for SSDP on port 1900 should be UDP.
    sammyg2005
    2024-07-24, 01:04 AM
    (2024-07-23, 08:35 PM)TheDreadPirate Wrote: Comment out this block.
        ports:
          - 8096:8096
    First, I want to say thank you for your time and help. The UI is just Portainer.
    I commented out the block and same issue. Tried from the laptop using the Jellyfin app and from the browser. I also tried on the iOS device. I used http://192.168.31.100:8096 to connect to the server.  I checked the logs on the laptop for the app and this is what I got:
    2024-07-23 20:46:55.809 [info] unknown @ 0 - JS: TypeError: Failed to fetch
    Here is the output from the commands you asked about
    UFW
    $ sudo ufw status verbose
    [Status: active
    Logging: on (low)
    Default: deny (incoming), allow (outgoing), deny (routed)
    New profiles: skip
    To                        Action      From
    8096/tcp                  ALLOW IN    Anywhere
    7359/udp                  ALLOW IN    Anywhere
    Anywhere                  ALLOW IN    192.168.30.0/23
    1900/udp                  ALLOW IN    Anywhere
    Docker
    $ sudo docker inspect jellyfin
            "Id": ,
            "Created": "2024-07-23T20:32:16.019842855Z",
            "Path": "/init",
            "Args": [],
            "State": {
                "Status": "running",
                "Running": true,
                "Paused": false,
                "Restarting": false,
                "OOMKilled": false,
                "Dead": false,
                "Pid": 246509,
                "ExitCode": 0,
                "Error": "",
                "StartedAt": "2024-07-23T20:32:22.994518204Z",
                "FinishedAt": "0001-01-01T00:00:00Z"
            "Image": ,
            "ResolvConfPath": f",
            "HostnamePath": ,
            "HostsPath": ,
            "LogPath": json.log,
            "Name": "/jellyfin",
            "RestartCount": 0,
            "Driver": "overlay2",
            "Platform": "linux",
            "MountLabel": "",
            "ProcessLabel": "",
            "AppArmorProfile": "",
            "ExecIDs": null,
            "HostConfig": {
                "Binds": [
                    "/mnt/appdata/jellyfin:/config:rw",
                    "/mnt/data/media/:/data/media:rw"
                "ContainerIDFile": "",
                "LogConfig": {
                    "Type": "json-file",
                    "Config": {}
                "NetworkMode": "host",
                "PortBindings": {},
                "RestartPolicy": {
                    "Name": "unless-stopped",
                    "MaximumRetryCount": 0
                "AutoRemove": false,
                "VolumeDriver": "",
                "VolumesFrom": null,
                "ConsoleSize": [
                    0,
                    0
                "CapAdd": null,
                "CapDrop": null,
                "CgroupnsMode": "private",
                "Dns": null,
                "DnsOptions": null,
                "DnsSearch": null,
                "ExtraHosts": [],
                "GroupAdd": null,
                "IpcMode": "private",
                "Cgroup": "",
                "Links": null,
                "OomScoreAdj": 0,
                "PidMode": "",
                "Privileged": false,
                "PublishAllPorts": false,
                "ReadonlyRootfs": false,
                "SecurityOpt": null,
                "UTSMode": "",
                "UsernsMode": "",
                "ShmSize": 67108864,
                "Runtime": "runc",
                "Isolation": "",
                "CpuShares": 0,
                "Memory": 0,
                "NanoCpus": 0,
                "CgroupParent": "",
                "BlkioWeight": 0,
                "BlkioWeightDevice": null,
                "BlkioDeviceReadBps": null,
                "BlkioDeviceWriteBps": null,
                "BlkioDeviceReadIOps": null,
                "BlkioDeviceWriteIOps": null,
                "CpuPeriod": 0,
                "CpuQuota": 0,
                "CpuRealtimePeriod": 0,
                "CpuRealtimeRuntime": 0,
                "CpusetCpus": "",
                "CpusetMems": "",
                "Devices": [
                        "PathOnHost": "/dev/dri/renderD128",
                        "PathInContainer": "/dev/dri/renderD128",
                        "CgroupPermissions": "rwm"
                        "PathOnHost": "/dev/dri/card1",
                        "PathInContainer": "/dev/dri/card1",
                "DeviceCgroupRules": null,
                "DeviceRequests": null,
                "MemoryReservation": 0,
                "MemorySwap": 0,
                "MemorySwappiness": null,
                "OomKillDisable": null,
                "PidsLimit": null,
                "Ulimits": null,
                "CpuCount": 0,
                "CpuPercent": 0,
                "IOMaximumIOps": 0,
                "IOMaximumBandwidth": 0,
                "MaskedPaths": [
                    "/proc/asound",
                    "/proc/acpi",
                    "/proc/kcore",
                    "/proc/keys",
                    "/proc/latency_stats",
                    "/proc/timer_list",
                    "/proc/timer_stats",
                    "/proc/sched_debug",
                    "/proc/scsi",
                    "/sys/firmware",
                    "/sys/devices/virtual/powercap"
                "ReadonlyPaths": [
                    "/proc/bus",
                    "/proc/fs",
                    "/proc/irq",
                    "/proc/sys",
                    "/proc/sysrq-trigger"
            "GraphDriver": {
                "Data": {
                "Name": "overlay2"
            "Mounts": [
                    "Type": "bind",
                    "Source": "/mnt/data/media",
                    "Destination": "/data/media",
                    "Mode": "rw",
                    "RW": true,
                    "Propagation": "rprivate"
                    "Type": "bind",
                    "Source": "/mnt/appdata/jellyfin",
                    "Destination": "/config",
                    "Mode": "rw",
                    "RW": true,
            "Config": {
                "Hostname": "arch-server",
                "Domainname": "",
                "User": "",
                "AttachStdin": false,
                "AttachStdout": true,
                "AttachStderr": true,
                "ExposedPorts": {
                    "8096/tcp": {},
                    "8920/tcp": {}
                "Tty": false,
                "OpenStdin": false,
                "StdinOnce": false,
                "Env": [
                    "PUID=1000",
                    "PGID=1000",
                    "UMASK=0002",
                    "TZ=America/New_York",
                    "JELLYFIN_PublishedServerUrl=192.168.31.xxx",
                    "PATH=/lsiopy/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
                    "HOME=/root",
                    "LANGUAGE=en_US.UTF-8",
                    "LANG=en_US.UTF-8",
                    "TERM=xterm",
                    "S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0",
                    "S6_VERBOSITY=1",
                    "S6_STAGE2_HOOK=/docker-mods",
                    "VIRTUAL_ENV=/lsiopy",
                    "LSIO_FIRST_PARTY=true",
                    "NVIDIA_DRIVER_CAPABILITIES=compute,video,utility"
                "Cmd": null,
                "Image": "lscr.io/linuxserver/jellyfin:latest",
                "Volumes": {
                    "/config": {}
                "WorkingDir": "/",
                "Entrypoint": [
                    "/init"
                "OnBuild": null,
                "Labels": {
                    "build_version": "Linuxserver.io version:- 10.9.8ubu2204-ls23 Build-date:- 2024-07-21T06:16:07+00:00",
                    "com.docker.compose.config-hash":
                    "com.docker.compose.container-number": "1",
                    "com.docker.compose.depends_on": "",
                    "com.docker.compose.image":
                    "com.docker.compose.oneoff": "False",
                    "com.docker.compose.project": "mediastack",
                    "com.docker.compose.project.config_files": "/data/compose/25/docker-compose.yml",
                    "com.docker.compose.project.environment_file": "/data/compose/25/stack.env",
                    "com.docker.compose.project.working_dir": "/data/compose/25",
                    "com.docker.compose.replace": ,
                    "com.docker.compose.service": "jellyfin",
                    "com.docker.compose.version": "2.26.1",
                    "maintainer": "thelamer",
                    "org.opencontainers.image.authors": "linuxserver.io",
                    "org.opencontainers.image.created": "2024-07-21T06:16:07+00:00",
                    "org.opencontainers.image.description": "[Jellyfin](https://github.com/jellyfin/jellyfin) is a Free Software Media System that puts you in control of managing and streaming your media. It is an alternative to the proprietary Emby and Plex, to provide media from a dedicated server to end-user devices via multiple apps. Jellyfin is descended from Emby's 3.5.2 release and ported to the .NET Core framework to enable full cross-platform support. There are no strings attached, no premium licenses or features, and no hidden agendas: just a team who want to build something better and work together to achieve it.",
                    "org.opencontainers.image.documentation": "https://docs.linuxserver.io/images/docker-jellyfin",
                    "org.opencontainers.image.licenses": "GPL-3.0-only",
                    "org.opencontainers.image.ref.name": "4da6ce3a47411ec49af1903327f22c7cda1d5b72",
                    "org.opencontainers.image.revision": "4da6ce3a47411ec49af1903327f22c7cda1d5b72",
                    "org.opencontainers.image.source": "https://github.com/linuxserver/docker-jellyfin",
                    "org.opencontainers.image.title": "Jellyfin",
                    "org.opencontainers.image.url": "https://github.com/linuxserver/docker-jellyfin/packages",
                    "org.opencontainers.image.vendor": "linuxserver.io",
                    "org.opencontainers.image.version": "10.9.8ubu2204-ls23"
            "NetworkSettings": {
                "Bridge": "",
                "SandboxID": ,
                "SandboxKey": "/var/run/docker/netns/default",
                "Ports": {},
                "HairpinMode": false,
                "LinkLocalIPv6Address": "",
                "LinkLocalIPv6PrefixLen": 0,
                "SecondaryIPAddresses": null,
                "SecondaryIPv6Addresses": null,
                "EndpointID": "",
                "Gateway": "",
                "GlobalIPv6Address": "",
                "GlobalIPv6PrefixLen": 0,
                "IPAddress": "",
                "IPPrefixLen": 0,
                "IPv6Gateway": "",
                "MacAddress": "",
                "Networks": {
                    "host": {
                        "IPAMConfig": null,
                        "Links": null,
                        "Aliases": null,
                        "MacAddress": "",
                        "DriverOpts": null,
                        "NetworkID": ,
                        "EndpointID": ,
                        "Gateway": "",
                        "IPAddress": "",
                        "IPPrefixLen": 0,
                        "IPv6Gateway": "",
                        "DNSNames": null
    2024-07-24, 02:30 AM
    Are the other client devices on the same subnet?
    192.168.30.0/23
    Since you have a firewall rule that only allows connections from addresses in that subnet.
    sammyg2005
    2024-07-24, 05:08 AM (This post was last modified: 2024-07-24, 09:10 AM by sammyg2005. Edited 1 time in total.)
    (2024-07-24, 02:30 AM)TheDreadPirate Wrote: Are the other client devices on the same subnet?
    192.168.30.0/23
    Yes. All of my DCHP devices (mostly mobile devices) are on the 192.168.30.xxx pipe and 192.168.31.xxx are my static devices. I have a home assistant server that I log into daily from my phone or iPad and they are all local. Do you think that rule may be a problem? I wouldn’t think I need any samba or ssh setup to get into the Jellyfin server or am I wrong? I’m new to docker so I’m not sure if I’m crossing over from my home network into the container correctly. All of the apps work as they should on the host. I haven’t tried logging into those from other clients yet. I’m just starting with Jellyfin.
    2024-07-24, 02:19 PM (This post was last modified: 2024-07-24, 02:20 PM by TheDreadPirate. Edited 1 time in total.)
    No. It shouldn't be a problem. I was just making sure the client IPs weren't overlooked.
    Having said that. For testing purposes, what happens when you disable it? Jellyfin is one of two containers not using bridge networking.
    sammyg2005
    2024-07-24, 03:46 PM
    (2024-07-24, 02:19 PM)TheDreadPirate Wrote: No.  It shouldn't be a problem.  I was just making sure the client IPs weren't overlooked.
    I removed the rule and same issue. I updated the container and tried again, no dice with any device. The other one not connected to the bridge is qbt, but that is being tunneled through gluetun, so that makes sense. When I look at 'docker inspect jellyfin' should it show an IP address or because it is 'host' it stays blank? I haven't touched anything in the router, which i would not have expected to do that, but is there something I need to do in the router?
                "Bridge": "",
                "SandboxID": "removed",
                "Ports": {},
                "EndpointID": "",
                "Gateway": "",
                "IPAddress": "",
                "IPPrefixLen": 0,
                "IPv6Gateway": "",
                "MacAddress": "",
                "Networks": {
                    "host": {
                        "IPAMConfig": null,
                        "Links": null,
                        "Aliases": null,
                        "MacAddress": "",
                        "DriverOpts": null,
                        "NetworkID": "removed",
                        "EndpointID": "removed",
                        "Gateway": "",
                        "IPAddress": "",
                        "IPPrefixLen": 0,
                        "IPv6Gateway": "",
                        "DNSNames": null
    2024-07-24, 04:11 PM
    When using host networking it shouldn't show any IP address.
    Is your router on the same subnet as all your clients/server? What happens if you setup port forwarding on your router for port 8096 on the host's IP address?
    sammyg2005
    2024-07-24, 05:17 PM
    (2024-07-24, 04:11 PM)TheDreadPirate Wrote: When using host networking it shouldn't show any IP address.
    Unfortunately the same outcome. And the router is on the same subnet 192.168.31.xxx
    I am not sure if I need to do the nuclear option and start a clean build.
    2024-07-24, 06:33 PM
    What are the names of the host NICs on your system?
